M Audio MobilePre Issues - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss M Audio MobilePre Issues in the Subwoofer Equalization | Calibration forum; M Audio MobilePre Issues Hi guys, newbie here to REW and after two days I'm still having issues setting everything up. I'm using a ...
Old 10-06-06, 11:10 AM   #1 (Link)
New Member
Alias: Nat Ward
User: #2902
Since: Oct 2006
Nat Ward is offline
Hi guys, newbie here to REW and after two days I'm still having issues setting everything up. I'm using a M-Audio MobilePre soundcard and ECM8000 mic for measurements.
Basics:
ECM8000 to MobilePre via XLR cable into channel 2 mic input
MobilePre to processor via 1/4" to RCA adaptor from channel 2 output
I've been able to set the measurement level, and set the input volume level, my problem is that I need to turn the channel level up on the MobilePre almost the whole way to get a -18dB input level.
I can then calibrate the REW SPL meter without issues. What I am having a problem with is calibrating my soundcard. I can run the calibrate function over and over and never get the same response. I am using the 1/4" jack channel 1 output into the 1/4" jack channel 2 input. Here is an example:
It looks like it's clipping, but the only way to resolve that is to turn down the input channel level knob on the MobilePre down, which then makes the input level below -30dB. And even then I can run the soundcard calibrate function and still get a funky graph. I had similar issues the first day I tried this but they went away after I loaded the soundcard's drivers. I uninstalled and reinstalled them again today without luck. I have "direct monitor" turned off in the soundcard menu.
Help! Is my soundcard hosed? I don't like the idea of dropping >$200 on a setup that doesn't work. Does anyone else run the ECM8000 with the MobilePre have the same issue with the channel level needing to be cranked up?
Thanks
-Dissapointed Nat
Old 10-06-06, 11:39 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: M Audio MobilePre Issues
Looks like a feedback path in the soundcard mixer, for example the input signal is not muted in the output mixer. REW won't be doing that for you because you haven't selected an input and an output, so you'll need to do it manually. The only signal which should not be muted in the playback part of the mixer is WAVE, mute everything else (if the MobilePre mixer is not too clear on that try looking at the Windows mixer settings to see what they show).
Old 10-06-06, 12:17 PM   #3 (Link)
New Member
Alias: Nat Ward
User: #2902
Since: Oct 2006
Nat Ward is offline
Thanks for the response John. If I mute all outputs except WAVE I get "Unable to detect feedback loop....." so I left things alone (only thing muted is direct monitor)
I was able to play around with things again and turned the input knob down to about 1/4 volume, this gave me a good looking soundcard calibration result that I was able to repeat (and matched my results from 2days ago). See below:
I then went back and ran "set input volume" to see where the responses was, and as you can see it's off the charts low. I only get peaks in the mid -30dBs.
I left things alone and then proceeded to set the SPL meter. I can adjust the level on my processor and REW follows accordingly, will I have problems if the input volume is low as noted above?
I ran an automatic measurement on channel left, as directed by the setup guide, and came upwith this. Any reason why the responses are at the levels they are (soundcard cal now at ~85dB and measured at ~95dB?)
It looks like I'm getting some sort of improvement here, but not sure - could be all screwed up! Thanks again.
Nat
Old 10-06-06, 12:25 PM   #4 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
The soundcard cal looks fine, and it doesn't matter that you use a different volume setting to derive that. Set the input volume using your mic as you had it earlier (i.e. volume nearly full to get -18dB when playing the cal signal), re-calibrate the SPL reading and all should work OK.
Old 10-06-06, 12:29 PM   #5 (Link)
New Member
Alias: Nat Ward
User: #2902
Since: Oct 2006
Nat Ward is offline
I was just able to make a sweep (as set up above), and to be honest things look good. The results pretty much match (peaks and nulls) a similar sweep I did by hand using the RS meter, of course with better clarity on REW. The only thing that happened was the window popped up saying that I had low signal level.
Should I be able to take measurements like this? Can you calibrate a soundcard at a lower input level and then turn up the input level to make REW happy with it's -18dB desire? I know I'd have to adjust the SPL meter, I just don't know if that affects the results.
Sorry for the million questions!
Nat
Old 10-06-06, 12:31 PM   #6 (Link)
New Member
Alias: Nat Ward
User: #2902
Since: Oct 2006
Nat Ward is offline
You read my mind John, answered the question before I asked
I'll adjust things again and start playing, whew!
Similar Threads
Audio features in Vista GreggP Computers | Games | HTPC | Digital Devices 9 10-10-06 11:15 AM
What Everybody Ought to Know About Vandersteen Audio geekwithfamily Home Theater, Audio and Video News 0 10-06-06 02:22 AM
More info on BFD pro midi interface issues? tejas gordo BFD Forum 4 09-14-06 11:28 PM
Server issues... Sonnie Forum Announcements | News 0 07-07-06 08:30 AM
DVD lip synch issues rcarlton Movies | TV Shows | Hollywood 1 06-03-06 08:35 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
