| REW Forum Subwoofer inverted impulse responseDiscuss Subwoofer inverted impulse response in the Equalization | Calibration forum; Subwoofer inverted impulse response Hi guys,
I've been using REW for quite sometime now, and I'm currently digging a little more on the interpretation ... |
Views: 449 - Replies: 16
| Subwoofer inverted impulse response Hi guys, I've been using REW for quite sometime now, and I'm currently digging a little more on the interpretation of the impulse response. Attached to this post is my subwoofer impulse response. As you can see the strongest peak (100%) is positive. In order to obtain that positive peak I had to invert the polarity of my sub ( jbl 2241h in a bass reflex cab). If I hadn't done the inversion, my subwoofer impulse reponse would be the same but inverted, with the strongest peak being negative. So my question is: is this natural inverted impulse response a characteristic of a bass reflex cabinet? Should I invert the polarity of the Jbl in order to get a positive 100% peak, or should I leave it just the way it is? I just wanted to have your thoughts on that, because otherwise I'm really satisfy with my system bass response. Thanks in advance | ||||
| | #2 | |||||
| Re: Subwoofer inverted impulse response Quote:
brucek | |||||
| | #3 | ||||
| Re: Subwoofer inverted impulse response Thanks Brucek, So, I should return the polarity to its original setting... But If I do that my impulse will be negative, which is not the case for the other channel I' ve measured... The impulse response attached with my previous post was capture from my sub only, and the results were the same even when I changed the mic position and put it very close to the JBL ( 1")... All of my other speakers (jbl 2445, 2425, d123,) I've tested shows a positive impulse when the polarity is correctly set. Why is is that for a subwoofer it seems to be the other way around? Regards, | ||||
| | #4 | ||||
| Re: Subwoofer inverted impulse response The sub amp might be inverting, or the driver connections reversed. | ||||
| | #6 | ||||
| Re: Subwoofer inverted impulse response The response should be positive for any kind of sub. Some mic amps are also inverting, but since you indicate all the other channels have positive polarity the inversion must be in the sub path. | ||||
| | #7 | |||||
I always figured that there were so many pieces of equipment involved in the measurement chain that could invert the signal that I had always discounted what REW showed for the impulse with respect to positive or negative. Here's my two subs from my two different systems. Each used the same mic, cables and mixer preamp, but the computers and AV systems are different. First pic is my Energy EPS-150 sub showing a positive impulse and the second is my very nice Servo-15 showing a negative impulse. ![]() To it seems insignificant, as the resultant signal when combined with the mains is cleaned up with the phase control. ![]() ![]() brucek | |||||
| | #8 | ||||
| Re: Subwoofer inverted impulse response Perhaps I should qualify my statement by adding "when the sub's phase control is set to 0/normal". If phase is set to invert then the impulse would reflect that. | ||||
| | #9 | |||||
brucek | |||||
| | #10 | ||||
| Re: Subwoofer inverted impulse response No effect, in the processor it really is just altering delays. | ||||
| | #11 | |||||
Does the phase control (as a low Q, all pass filter) not offer linear phase response over its range and result in the same effect as the time delay? brucek | |||||
| | #12 | ||||
| Re: Subwoofer inverted impulse response Hey guys, glad to see this thread encourages discussion! I have another question, when looking at the graph posted by Brucek I noticed that the shape correspond (roughly) to my sub graph, but in the time domain, my sub peak is at + 5ms where Brucek's one is located at exactly 0ms. What hypothesis can we infer out of these observations? | ||||
| | #13 | ||||
| Re: Subwoofer inverted impulse response No. The typical normal/invert sub "phase" control is simply a switchable inversion. For variable controls it is an all pass that is reasonably linear through the middle of its operating range but not at the ends. | ||||
| | #14 | |||||
| | #15 | ||||
| Re you working Thank you John, So, if I want to align (temporally) my sub with my mains, by capturing the sub impulse and afterwards my mains impulse, I cannot use REW to draw any conclusions from potential delay between the impulse peaks of the mains and the sub? Is it a feature you are currently working on for REW? Regards | ||||
| | #16 | |||||
| Re: Re you working Quote:
Yes, V5 allows a left channel loopback to be used as a timing reference. | |||||
