Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss First Response...doesn't look right in the Equalization | Calibration forum; First Response...doesn't look right I read over the help documentation, and I'm pretty confident I've calibrated properly, but these response graphs look a little ...
Views: 694 - Replies: 17
Old 07-07-09, 09:37 PM   #1
Alias: Nik
Loc: Denver
User: #24559
Since: Aug 2008
  ngiachino is online now
I read over the help documentation, and I'm pretty confident I've calibrated properly, but these response graphs look a little crazy past 180hz.
I'm using a behringer emc8000 mic, behringer 802 mixer, and my onboard soundcard. Measurements were taking from my listening position.
Here is an example of the graph I got...(remove *....couldn't post link since I'm new here)
img21.imagesh*ck.us/img21/5048/nikg.jpg
Old 07-07-09, 10:05 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: First Response...doesn't look right
Go to the Post padding thread and make 5 dummy posts and then post your pic.
Old 07-07-09, 10:08 PM   #3
Alias: Nik
Loc: Denver
User: #24559
Since: Aug 2008
Got it...
Old 07-07-09, 10:11 PM   #4
Alias: Nik
Loc: Denver
User: #24559
Since: Aug 2008
Pic of bookshelf speaker set in built-in bookshelves.
[IMG][/IMG]
Old 07-07-09, 10:35 PM   #5
Alias: bigbadbill
Loc: Newcastle NSW
User: #26128
Since: Sep 2008
  robbo266317 is offline
That's not a bad response for a bookshelf.
For full range you may want to use 1/3 octave filtering.
Silence is Golden but Duct Tape is Silver.
DIY completed:
http://www.hometheatershack.com/forums/exodus-audio/17798-shiva-x-extended-bass-shelf.html
Old 07-07-09, 10:38 PM   #6
Alias: Nik
Loc: Denver
User: #24559
Since: Aug 2008
The speakers are a diy build I did with the help of some forum members. They use usher 8945p mid-range and peerless hds tweeters in a .5cuft enclosure. This is my first xover...so I'll probably look to doing some tweaking once I know for sure I'm generating these measurements correctly.
Old 07-08-09, 01:43 AM   #7
Alias: Wackii
Loc: I ain't tellin ya!
User: #1530
  wackii is offline
ngiachino wrote: View Post
[IMG][/IMG]
I wish my response graph looks like this at listening position.
Al,
Old 07-08-09, 06:49 AM   #8
Alias: brucek
User: #6
  brucek is offline
You're being overly kind to yourself with respect to your graphing axis values.
You're using a vertical axis of -60 to +130dB (190dB spread). This would make most speakers look great. You should switch to the standard 60dB spread we use here with a vertical axis of 45dB-105dB. This centers the 75dB target around a plus and minus 30dB spread.
For full range measurements you need to turn on smoothing. This feature removes the comb filtering and reveals the underlying trend of the signal for easier evaluation.
Old 07-08-09, 08:49 AM   #9
Alias: Nik
Loc: Denver
User: #24559
Since: Aug 2008
Changed the axis and put on 1/3 octive smoothing...
Old 07-08-09, 08:54 AM   #10
Alias: brucek
User: #6
  brucek is offline
Yeah, that's good.
Quite a dip at ~200Hz to examine..
I guess now you can do some near-fields or outside measures to try and remove external influences, so you can see how the speakers are performing.....
response...doesn't
Bookmark and Share
Dish Network
