REW Forum
REW .cal file correction factor + SPL meter reading = true SPL?
Discuss REW .cal file correction factor + SPL meter reading = true SPL? in the Equalization | Calibration forum; REW .cal file correction factor + SPL meter reading = true SPL? Hello Forgive the intrusion but could I trouble you for a moment? If I'm taking readings from my Galaxy 140 ...
Views: 298 - Replies: 3
Old 07-08-09, 03:28 PM   #1
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Hello
If I'm taking readings from my Galaxy 140 using C-weighting and adding the .cal file correction factor am I reading the true SPL?
For example: I play REW generated sinewaves through my sub:
I read 106dB @ 10Hz @ 1 metre (39.4") on my Galaxy 140 SPL meter.
I add the 13.45dB correction factor (taken from the REW text .cal file) to my 106dB(C) meter reading and then assume that I am actually outputting 119.45dB measured at 1 metre @ 10Hz.
Is the assumed ~120dB @ 10Hz true or false? (I'm ignoring any harmonic distortion components for the moment)
Old 07-08-09, 03:36 PM   #2
Alias: SubNoob
Loc: Newcastle, WA
User: #32615
Since: Jan 2009
  wadesi is offline
Re: REW .cal file correction factor + SPL meter reading = true SPL?
Good question...
Old 07-08-09, 03:56 PM   #3
Alias: brucek
User: #6
  brucek is offline
Yes. The end result of applying the cal file is to create a flat mic response. If the meter conformed to a perfect C-Weight response, then we wouldn't need a cal file, and we could simply check the C-Weight box in REW and it would apply a reverse C-Weight to the readings, and the result would be flat. That's a perfect world, but in the real world, no meter seems to exactly conform to the C-Weight curve, and especially at the extremes. So, we apply a curve (cal file) that more closely matches the meter over the wide extreme low frequencies we desire, and the result hopefully is flat.
Old 07-08-09, 06:05 PM   #4
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
brucek wrote: View Post
Perfect! It seemed so obvious that I didn't quite believe it.
In a moment of doubt over an unlikely reading I feared the .cal corrections were unique to REW's inner workings.
I wanted to be certain before I accepted the results of my testing as genuine.
Many thanks.
Chris
.cal, correction, factors, file
