REW Forum
Trying to hook up to use REW w Apple laptop
Discuss Trying to hook up to use REW w Apple laptop in the Equalization | Calibration forum; Trying to hook up to use REW w Apple laptop I understand that it takes an external soundcard to operate the REW software with the Radio Shack SPL meter. My ...
Views: 236 - Replies: 3
Old 07-20-09, 02:58 PM   #1
Alias: bartc
Loc: Foster City, CA
User: #30725
Since: Dec 2008
  bcharlow is offline
I understand that it takes an external soundcard to operate the REW software with the Radio Shack SPL meter. My son has a recent vintage Apple laptop that has the mic in port, but that's not supposed to work. He doesn't have a soundcard per se, but what he does have is an M-box 2 with Protools software. He doesn't know how (or if) it will work with the REW, but you might, since this is some kind of common music/digital input device like a soundcard for Apple computers.
Can you help?
Thanks.
Old 07-20-09, 03:12 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Trying to hook up to use REW w Apple laptop
Is it USB or Firewire?
Old 07-20-09, 03:35 PM   #3
Alias: bartc
User: #30725
Since: Dec 2008
  bcharlow is offline
USB, he says.
Old 07-20-09, 03:54 PM   #4
Alias: brucek
User: #6
  brucek is offline
There have been a few posts from people using the digidesign mbox products on mac (USB only), and it seems like the biggest problem is ensuring all the features and monitoring are shut off.
You use the line-in and line-out (right channel) for REW. See if you can accomplish the soundcard calibration routine and get a good file from that. It only involves connecting a single loopback from line-out to line-in on the right channel and running the soundcard cal routine. If successful, then the rest is easy.
apple, hook, laptop
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
