| REW Forum Weird Looking CalibrationDiscuss Weird Looking Calibration in the Equalization | Calibration forum; Weird Looking Calibration Hi
I've just calibrated my soundcard (via loopback), and while the routine seemed to run fine, I was surprised by ... |
Views: 446 - Replies: 17
| Weird Looking Calibration Hi I've just calibrated my soundcard (via loopback), and while the routine seemed to run fine, I was surprised by how rough the frequency curve looked. The device is an Apogee Duet, so it's got extremely good converters - I would have thought that this would have meant I'd get a pretty flat calibration graph. Here's what it looks like: ![]() Obviously I could be overestimating the unit, and this might be completely correct, however, any pointers would be great... | ||||
| | #2 | ||||
| Re: Weird Looking Calibration I'm no expert but it looks like you're getting feedback. Is there a setting for "Record Monitoring" that might be enabled? The early bird may get the worm, but the second mouse gets the cheese. | ||||
| | #4 | ||||
| Re: Weird Looking Calibration OK, so I did a bit more investigation, and decided to record what REW was actually sending as the output signal. The left channel sounds fine, just a regular 1kHz tone, but the right is just a wierd buzzing sound. I use the Duet all the time for recording and playback, and nothing else makes that noise, so I think that isolates it to REW. Furthermore, it don't think it could be a feedback issue, as a) the left channel with the same setup has no problems, and b) it generates the noise irrespective of how loud I set the right channel's input volume. Click here for a stereo capture of what's happening. I think it's safe to ignore the glitching noises occurring on the left channel, as they're not there when I'm listening - I figure they're just artifacts created by the recording software.... Thanks for all the assistance so far, I'm fairly new to all this so the help's really appreciated ![]() | ||||
| | #5 | ||||
| Re: Weird Looking Calibration You're not the first one to notice noise in an audio channel with a Mac. Seems a bit strange that it's only on one channel though. Be sure to have the Default Device selected. brucek | ||||
| | #6 | ||||
| Re: Weird Looking Calibration I'm also having a problem with the right channel signal. Left work flawlessly, but in the right channel there's always a buzzing sound. I'm going digital out from the Mac, and if I try to get a measurement for both channels, the right will give me trouble. It was not a problem when I used a Windows machine. żDoes anyone know what going on? | ||||
| | #9 | |||||
| Re: Weird Looking Calibration Quote:
brucek | |||||
| | #10 | |||||
Regards, | |||||
| | #11 | |||||
brucek | |||||
| | #12 | |||||
I take the DAC's analog output and loop it back to the M-Audio analog input for calibration. For measurements I route the analog out of the DAC back to the PreAmp and plug the microphone to the analog in of the M-Audio. I hope this makes sense. Regards, | |||||
| | #13 | |||||
What are your intentions using it in this format? brucek | |||||
| | #14 | |||||
By going digital from the M-Audio when playing music, I'm trying to avoid to have the soundcard do a D/A conversion, only to have the 2496 do A/D so it can apply the filters, and then do another D/A, either by the 2496's own or a separate DAC, going out to the preamp. I tried to calibrate the equipment with no filters on the 2496, hoping to get a cal file that compensates for any misbehavior. I still don't understand why new calibration would be needed when filters are applied. I thought it best to take measurements with the same setup I use for listening, but if it causes a problem I'd readily use the soundcard's analog out for testing, I don't think the triple conversion would make much of a difference when playing a sweep tone. However I'd greatly appreciate if you could clear things out for me. Regards, | |||||
| | #15 | |||||
Whatever you use for the loopback to create a calibration file, then that is your test equipment and must not be altered. It is the standard. You use it to measure your 'system'. Then any results are from the 'system' and not the 'test equipment'. brucek | |||||
| | #16 | |||||
Regards, | |||||
| | #17 | ||||
| Re: Weird Looking Calibration Hi there, just found this search on a thread and thought it was fairly close to my problem. I'm also having issues calibrating an M-Audio Fast Track Pro. I've read through the instructions, have everything set up, however I have no options to disable the feedback loop. I'm getting a very erratic reading. Can anyone help? I've been through a few threads but other than it being a mac issue I can't find much else. I'm using an M-Audio Fast Track Pro and a PPC Mac on 10.4.11 I've also tried the test with a Digidesign 192 and got a similar reading. I also tried the M-Audio with my Macbook which is an Intel model but I'm still getting the same crazy read outs. | ||||
| Bookmarks |
| Tags |
| calibration, weird |
| Thread Tools | |
