REW Forum
My first REW try.
Discuss My first REW try. in the Equalization | Calibration forum; My first REW try. Here is a look at the REW sweep of my Martin Logan Descent I sub using a Behringer UCA202 as ...
Views: 340 - Replies: 6
Old 08-04-09, 11:09 AM   #1
Alias: Marty
Loc: Raleigh, NC
User: #39613
Since: Jul 2009
  mjb1023 is offline
My first REW try.
Here is a look at the REW sweep of my Martin Logan Descent I sub using a Behringer UCA202 as my sound card and a new Radio Shaft analog SPL meter.
Since I am a Noob at this, I would appreciate any input or advice.
Name:  day one, no eq.jpg
Old 08-04-09, 12:19 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: My first REW try.
Very nice response. It certainly goes low. If you're not using any external EQ, then you're quite lucky - you don't need any....
Use the standard vertical axis of 45dB-105dB using the Graph Limits button in the top right corner of REW.. You're being kind to yourself with that wide axis you're using.
Old 08-04-09, 06:38 PM   #3
Alias: Marty
Loc: Raleigh, NC
User: #39613
Since: Jul 2009
  mjb1023 is offline
Thanks brucek for the suggestion about the graph. I still might buy a BFD to smooth out the spikes at 41 and 65 hz. Here is the adjusted graph...a little more ragged looking now that it is "zoomed in".
Name:  day 1, 45-105 db graph adjust.jpg
Old 08-04-09, 07:32 PM   #4
Alias: brucek
User: #6
  brucek is offline
Still a fairly good response though. have you tried moving the sub around at all to better the peak at 40Hz? Sometimes a small change will affect a peak.
Did you also try moving the listening position mic around a few feet at least from the sweet spot to observe changes.
Old 08-04-09, 07:57 PM   #5
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Here is a look at the REW sweep of my Martin Logan Descent I sub...
Very impressive! I wasn't aware that any major manufacturer made an off-the-shelf sub that would get below 10 Hz!
Old 08-04-09, 09:33 PM   #6
Alias: Marty
Loc: Raleigh, NC
User: #39613
Since: Jul 2009
  mjb1023 is offline
Yeah, I'm kind of surprised myself because Martin Logan only rates the Descent I to 18hz. The only thing I can figure is that I have adjusted the Descent's 20hz eq knob to +4db and the 50hz knob to -3db when I first set up the sub. Maybe that boost at 20hz is working some magic in the infrabase as well
I will play with REW a little more tomorrow.
Old 08-06-09, 07:53 AM   #7
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
mjb1023 wrote: View Post
Is it placed in a corner? That will also help boost the low end. Other than that, I would think we should see the response naturally start to roll off and it is not.
try.
