REW Forum
Velodine EQ or REW
Discuss Velodine EQ or REW in the Equalization | Calibration forum; Velodine EQ or REW I have a Velodyne DD-15 coming (present) and am wondering if I'm better off equalizing it with REW + BFD ...
Views: 235 - Replies: 1
Old 08-10-09, 07:25 PM   #1
New Member
Alias: josko
User: #37379
Since: May 2009
  josko is offline
Velodine EQ or REW
I have a Velodyne DD-15 coming (present) and am wondering if I'm better off equalizing it with REW + BFD or with the Velodyne equalizer setup. I don't mind the time to calibrate, so I'm wondering which of the two options is more capable. (I already have a BFD.)
Thanks in advance.
Old 08-10-09, 09:12 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Velodine EQ or REW
I would use the internal Velodyne EQ if there is enough control and filters for the problems that you may (or may not) have.
You first have to run REW and find out if you need EQ. Then you can see if the Velodyne EQ can do the job.
Many people simply have a single peak that is easy to remove. The BFD adds another device in the chain that has to digitize and then turn the signal back into analog. No need to use it if it's not needed.
velodine
