| REW Forum Mic cal file questionDiscuss Mic cal file question in the Equalization | Calibration forum; Mic cal file question I should know this by now, but when I use a mic cal file does REW automatically adjust the measured ... |
Views: 253 - Replies: 4
| Mic cal file question I should know this by now, but when I use a mic cal file does REW automatically adjust the measured response accordingly? For example, in the plot below, does the sub measurement include a compensation for the rolloff of the ECM-8000, or should the mic rolloff be subtracted from the measurement? The mic cal in this plot is the generic ECM-8000 from here, but I have a calibrated ECM-8000 on order from Cross-Spectrum, since I want to zero in a little better on my BFD settings. Thanks. No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced. | ||||
| | #2 | ||||||
| Re: Mic cal file question Quote:
brucek | ||||||
| | #3 | ||||
| Re: Mic cal file question I must be doing something wrong, then. If I clear the mic cal file, the subwoofer FR plot looks the same. What am I missing? No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced. | ||||
| | #4 | |||||
Click the IR Windows icon (in the top right corner of REW). Click Apply Windows. This is required since the soundcard calibration and mic calibration files are not included in the impulse response. You need to apply the file change to the frequency response graph as I indicate above. brucek | |||||
| | #5 | ||||
| Re: Mic cal file question OK, thanks. That is the step I missed. I remember doing that when I first loaded REW, but I re-installed the OS on the laptop since then and forgot to add that step. No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced. | ||||
