| REW Forum Help in understanding REWDiscuss Help in understanding REW in the Equalization | Calibration forum; Help in understanding REW I have finally made my first few full range plots of my system. First, thanks to all who did such ... |
Views: 288 - Replies: 5
| Help in understanding REW I have finally made my first few full range plots of my system. First, thanks to all who did such a great job with the software and the help files. This is a great boost to improving our audio experience. I am using an ECM 8000 on my Home Theater PC. I calibrated the audio card and have attempted to follow the directions as best I could. Following is a plot, actually it is 4 plots, made while I made changes to the mid range crossover settings on my system. Pretty neat to see the effect of just changing the mid range. However, I have two main questions. When I set the system up, the volume calibration was set to 75 dB. However, I notice the plot rarely reaches 75 dB. Only a few bass peaks reach that decibel level. Why is the plot not 'centered' around 75 dB, Is that something I am doing wrong? Second questions relates to the high frequency roll off starting around 6 kHz. This is where my tweeter crosses over. Is that a measurement problem, a room problem or another mistake in setting up the software on my part? In my search of the forum, I noticed many of the full range plots exhibit the same high frequency roll off. I am trying to understand the process better. Thank you for your help. ![]() | ||||
| | #2 | |||||
| Re: Help in understanding REW Quote:
Regards, Wayne | |||||
| | #4 | ||||||
You should also measure your tweeter near field (<12") with a horizontal on-axis setup to establish whether the room is having an effect. brucek | ||||||
| | #5 | |||||
| | #6 | ||||
| Re: Help in understanding REW I have taken measurements both with and without the generic mic calibration file. With the calibration, the dropoff is even worse. I will take some nearfield tests to determine if my reflection point absorbers are having too great an effect and attenuating the high frequencies excessively. I am now pointing the mic directly at the speaker being measured. Pointing the mic vertically again shows a bigger rolloff in the high frequency range. Thank you guys for taking the time to entertain my questions. I find I sometimes need to understand how something works rathen than just follow directions without knowing the basis for the instructions. | ||||
| Bookmarks |
| Tags |
| understanding |
| Thread Tools | |
