REW Forum
Data (correction values) beyond 100Hz?
Discuss Data (correction values) beyond 100Hz? in the Equalization | Calibration forum; Data (correction values) beyond 100Hz? Is there any data (correction values) beyond 100Hz? Like up to 20KHz? I just bought an FBQ2496 for my sub ...
Views: 653 - Replies: 4
Old 10-12-06, 02:07 PM   #1
NowWhat?
Inactive
Alias:
User: #
Posts: n/a
Re: Radio Shack SPL Meter Correction Values (All new *.cal files are published!)...
Is there any data (correction values) beyond 100Hz? Like up to 20KHz? I just bought an FBQ2496 for my sub and thought I'd use the unused half for my center channel speaker. I hate to waste half of a perfectly good device.
Old 10-12-06, 04:40 PM   #2
Alias: brucek
User: #6
  brucek is online now
Many find that using an equalizer in the mains/center/surround channels does little except add noise floor. Best to use room treatment for those channels.
Above 100Hz the RS meter fairly accurately tracks the standard C-weight curve applied by REW and as such it is uneccessary to include compensation in the cal file. Note that an RS meter is inaccurate above about 5Khz and shouldn't be used. If you want full range try a mic like the ECM 8000.
Old 10-12-06, 06:30 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Scott,
I can make some comments that may be helpful, but I don’t want to sidetrack this thread, which is about the SPL meter calibration files. You might want to open a new thread.
Old 10-12-06, 06:40 PM   #4
Alias: brucek
User: #6
Re: Data (correction values) beyond 100Hz?
Created a new thread to preserve original.......... now you can comment Wayne
Old 10-13-06, 12:06 AM   #5
NowWhat?
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
Thanks for that!
I thought my post was just deleted. Figured I ought to check around first before I had a about it.
