REW Forum
REW's silent ouput problem
Discuss REW's silent ouput problem in the Equalization | Calibration forum; REW's silent ouput problem I cannot get any sound out of REW, this makes calibration and REW's using impossible... I'm using Vista x64 + ...
Views: 185 - Replies: 4
Old 08-19-09, 02:33 PM   #1
New Member
Alias: Jake
User: #22964
Since: Jul 2008
  Petomaani is offline
I cannot get any sound out of REW, this makes calibration and REW's using impossible... I'm using Vista x64 + Terratec Phase 22 + latest Java- and REW-versions.
Line-in works fine with default settings (I've chosen "default device" from line-in settings). Line-out or SPDIF won't work with specified device settings/"default device" chosen.
Every other Win-application produces sound in to the right output, but REW's still silent...
Old 08-19-09, 02:40 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: REW's silent ouput problem
When you examine Vistas Playback Devices Mixer, is the Soundcard selected as the default and the Levels tab showing any volume selected and not muted?
Old 08-20-09, 12:39 AM   #3
New Member
Alias: Jake
User: #22964
Since: Jul 2008
Yes, Terratec's line-in and -ouputs are selected as default devices and output hasn't been muted. It's quite weird that all other win applications uses the correct output as default...
Old 08-20-09, 07:03 AM   #4
Alias: brucek
User: #6
  brucek is offline
I note that the Terratec Phase 22 allows ASIO support. Hopefully you're not using that, Java (which REW uses) only supports WDM drivers for audio under Windows, not ASIO. So you have to ensure the card uses WDM drivers.
Old 08-20-09, 07:19 AM   #5
New Member
Alias: Jake
User: #22964
Since: Jul 2008
I noticed that too. I think that there's no WDM drivers for this sound card, I'll try to do measurements with the integrated soundcard...
ouput, problem, rew's, silent
