No Sound From REW - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
No Sound From REW
Discuss No Sound From REW in the Subwoofer Equalization | Calibration forum; No Sound From REW I have been trying for the past hour to get REW setup but I am getting no sound output when ...
Old 05-06-06, 08:50 PM   #1 (Link)
New Member
Alias: Blake
User: #258
Blaken is offline
Question No Sound From REW
I have been trying for the past hour to get REW setup but I am getting no sound output when I try to run the "set measurment level" Here is what I have done so far.
I have a fortissmo II with the newest drivers. The pc is runing windows media center 2005 SP 2.
Sound from the pc to reciever is fine. I can hear music from the pc when using media player
Bass management is fine. There is clearly bass coming from the pc to the sub.
I have tried selecting my soundcard and the defualt device.
I have selected all possible outputs including leaving it set to choose and then manualy adjusting the volume level in the master volume controll.
When REW is open I can not get sound from the pc at all. Media player does not output any sound. As soon as I turn it off media player is fine. I assume this is intended due to the nature of the program.
If anyone has any other suggestions please speak up. My last option is to swap out the soundcard. This particular card does have an optical output but I am using the analog output to the reciever because there is no way to loop the optical output to the analog input in order to calibrate REW. It is possible that REW is using the optical output but I don't know how I would over ride that. The optical out is turned off in the soundcard settings.
Old 05-06-06, 09:39 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: No Sound From REW
Hello Blaken... welcome to the Shack!
Once you choose your soundcard are you then selecting Input (LINE_IN) and Output (SPEAKER) beneath the chosen soundcard, as in the yellow highlighted example below...
Sonnie
Old 05-06-06, 10:23 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
REW expects only analog inputs and outputs to be used.
It takes a bit of time, but it's a great idea to read the REW help files. They are very informative and clear up most problems...
Old 05-06-06, 11:32 PM   #4 (Link)
New Member
Alias: Blake
User: #258
Blaken is offline
I am one of those rare people that read the manual for everythign I own. At work my coffe mug says RTFM (that is not a joke it actualy does). I read the entire help file before ever hooking my pc to my reciever.
As I had feared REW is outputing through my optical output on my sound card. I can select speaker or Digital audio device in REW and both come out the optical output. Now I just need to find a way to disable the optical out.
Old 05-06-06, 11:59 PM   #5 (Link)
New Member
Alias: Blake
User: #258
Blaken is offline
Go ahead and let this post die. I just installed a different sound card and it works fine.
Thanks
Old 05-07-06, 12:08 AM   #6 (Link)
Loc: Lower Alabama
Sonnie is offline
Too bad your other soundcard didn't work out... but at least you got it where you can use REW now.
Sonnie
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
