Would someone please explain these differences to me?
The ECM8000-CS.cal was created by Cross Spectrum labs. They employ the pressure method to calibrate the low frequency response, and the quasi-anechoic free-field on-axis method to calibrate the upper frequency response.
The pressure method is the most accurate method of measuring the frequency response of a microphone, however baffle diffraction is not accounted for when using this method for the higher frequencies.
Some microphone manufacturers provide the variance to offset the baffle diffraction, but Behringer does not. So, the two methods were used and the file combined to produce this calibration by Cross Spectrum.
