| REW Forum New sub, strange response...Discuss New sub, strange response... in the Equalization | Calibration forum; New sub, strange response... Just took ownership of an eD A7s-450 after coming from a Mirage Omni S8. Recently acquainted myself with REW and ... |
Views: 490 - Replies: 28
| New sub, strange response... Just took ownership of an eD A7s-450 after coming from a Mirage Omni S8. Recently acquainted myself with REW and created a nice graph of the Mirage in my 21'x13'x9' room. 4 wide Q filters, positioned against the side wall adjacent to L main-firing across the room: ![]() Unpacked the new sub and took a measurement after trying a couple locations: ![]() Ran Audyssey, dropped 5 filters on it and came up with this: ![]() Tried boosting those troughs...could this sub (in the same location as the Mirage was) be helped by placement? Thanks, Bryan | ||||
| | #2 | ||||
| Re: New sub, strange response... Hmm, that first graph looks like it has some serious smoothing applied. Typically you only apply smoothing to full-range measurements. The other graphs, you need to re-do them with the Frequency axis switched to logarithmic, and the vertical graph parameter to 45-105 dB. The bad news is, they'll probably look even worse than they do now... But to answer your question, yes repositioning can often improve response considerably. Or at least get you something that's easily equalized. Regards, Wayne | ||||
| | #3 | ||||
| Re: New sub, strange response... I thought mine were looking strange. I forgot to view in logarithmic form... Here is my graph of the new sub but in compliant form: ![]() Now with a slight house curve and 5 filters: ![]() Can anyone see where my house curve is wrong? All the others I see drop below 48dB before 120Hz. Is mine not steep enough? Oddly, 30Hz sine wave was the same SPL as 80Hz so I was unsure about how many dB my house curve should be. Also, is it true that I don't need to be concerned with that wide peak above my 80Hz crossover frequency. Oddly, my receiver doesn't seem to be applying the crossover while using the subwoofer multichannel input. I was thinking I should be doing better on extention with this sealed 18 incher... The last graph was with a 10dB boost @ 20Hz. | ||||
| | #4 | |||||
| Re: New sub, strange response... Wow, I had it backwards - the graphs look much, much better with the correct scaling. ![]() As far as your house curve target on the graph, first make sure you have REW set for the correct crossover frequency and slope that your receiver has. Yours looks like the frequency is high and/or the slope is only 12 dB/octave. Of course, if that’s correct for your receiver, then it is what it is... Quote:
As far as your crossover, if you just use the regular inputs (“Aux,” “CD,” etc.) you should be fine, as long as you have your speakers set to “small” and subwoofer “on” in the menu. Just unplug the speakers for a subwoofer reading. Regards, Wayne | |||||
| | #5 | ||||
| Re: New sub, strange response... Well, I'm just using the default setting of 80Hz crossover & 24dB/octave, can't determine why my target curve is up so high. I'll take another listen to those sine waves and come up with a proper house curve dB differential. Thanks for the input and replies! | ||||
| | #6 | ||||
| Re: New sub, strange response... Found a better position for the sub. Rear left corner firing @ 45 degree angle into room. I may have gone with too strong of a house curve... Listening to the 30Hz and 80Hz sine waves seemed like it required a 10dB boost to sound the same level. The following graph was what was obtained using 3 filters. 30Hz null and 49Hz peak just won't go away. ![]() Listening to a couple of spots in Kung Fu Panda made the overdone low-end obvious! Even though I calibrated to 80dB, there was so much low-end energy that even at -42dB in the receiver, the walls were shaking when the frequency dropped (skidoosh). It was frightening.. ![]() So back to (correctly) determining my house curve...maybe I should just run it flat? Could that potentially net me more extension? Last edited by Dr. Spankenstein; 08-25-09 at 10:34 AM.. | ||||
| | #7 | ||||
| Re: New sub, strange response... Looks good. If the 49 Hz peak won't go away, it's probably your main channels. If you're running them full range, change the setting in the receiver to "small." Do some music listening before you decide of your house curve is too steep. If everything seems overly bottom-heavy, lacking in upper bass, etc. then dial the curve back and re-EQ. Even as it is, the 10 dB house curve has pushed up your Target Curve pretty high. You might want try lowering it down to something between 75-80 dB, especially if you're having to use boosted filters to push everything up to it. Regards, Wayne | ||||
| | #8 | |||||||
| Re: New sub, strange response... Quote:
*light bulb* do I need to utilize another test tone to calibrate? Full-band pink noise? I just can't wrap my head around why it sounds well balanced during moderate low thumps and then when the frequency really drops-I find myself in a sonic blender! ![]() | |||||||
| | #9 | ||||||||
Vertical = 45dB-105dB Horizontal = 15Hz-200Hz. Quote:
brucek | ||||||||
| | #10 | ||||
| Re: New sub, strange response... My apologies. I will have to go back and get new JPEGs with the correct scaling. I thought you were just concerned with the vertical scaling. Sorry. ULF=Ultra Low Frequency. Forgive my cryptic acronyms. I took the sub on a tour of the room last night. The location mentioned had the smallest peak at that frequency. Every position and orientation required a MAJOR cut there. (Must be the wood panelling and the glazed brick wall that is causing all the gain. The blender comment was an attempt to explain the curious and sudden pressurization that happens when the signal's frequency falls into the upper teens. The sound seems balanced during normal passages. | ||||
| | #11 | |||||
Lets see a waterfall plot (using the same axis as the response graphs - and be sure it's log). It will probably show lots of ringing over the area you're concerned with. brucek | |||||
| | #12 | ||||
| Re: New sub, strange response... That's probably true. I forgot to re-run Audyssey after I moved the sub. ![]() I get to have tomorrow evening all to myself. I'll put together the required graphs and report back. Thank you so much for the troubleshooting and suggestions! | ||||
| | #13 | ||||||
| Re: New sub, strange response... Quote: Quote:
I can’t imagine a peak being as severe as 25 dB or more. Either you need to reposition the sub, or you have something in the house (besides the sub) making noise at that frequency when you’re measuring. Perhaps a before-EQ graph is on order... Regards, Wayne | ||||||
| | #14 | ||||
| Re: New sub, strange response... Took the sub on another tour of the room (sans Audyssey, no EQ), no luck in making the 21db peak go away even when measured from a few different listening positions. It's just there. The room surfaces are so reflective that changing the sub's orientation at each position made little to no difference. the biggest differences from graph to graph is when I change the listening/measuring position. And I'm not talking "move a few feet over", I'm talking 8" one way or the other drastically changes the peaks and nulls (even after Audyssey.) Basically I'm listening in a echo chamber! ![]() Attempted to add ~4dB of boost around 30Hz and that allowed me to reduce my amount of cut (at the 51Hz peak) to -11dB. Graph is looking pretty good (when measured from my 8"x8" sweet spot) now that I reduced it to a +6dB hard-knee house curve. Waterfall graphs tell the story, sorry I don't have them on hand. But there is upwards of 800ms of decay from 60Hz on down. Guess the next route is room treatments. Is anyone partial to SuperChunk traps vs DIY Tube traps? | ||||
| | #17 | ||||||
| Re: New sub, strange response... I was a bit off in my earlier post. You indicated that the peak was really severe, not that you couldn't get it to go away. In the scenario I mentioned with the main speakers, EQing the sub to eliminate a peak wouldn’t register at all, because the mains were still generating the peak. Sorry if I mislead you. Quote:
| | #18 | |||||
brucek | |||||
| | #19 | ||||||
![]() Quote:
| | #20 | |||||
brucek | |||||
| | #21 | ||||
| Re: New sub, strange response... Yes sir. Check levels (via the "Use subwoofer tone to set levels" in the "Settings" tab) to set the SPL meter to 75dB (by adjusting the master volume on receiver), then adjust the level on the "recording device"/line-in so that the VU meter reads -12dB. Click "FINISH" Click the "Calibrate" for SPL meter. Verfiy that the meter is reading ~75db (averages 76dB even on SLOW setting) and set the calibration number to 76dB. "OK". Run a 4 loop sweep with default settings (0Hz to 200Hz, -12dBfs, 256k) and the result is still a graph that shows @ 88dB. This is verified after the sweep by running the "set target level" in the "Target Settings". I don't get it? AVR setting for sub is -6dB and sub gain is at 12 o'clock.... Even when I use the receiver Test tones, they are still at the same level (although the mains & surrounds @ 75dB adn subwoofer to ~80dB.) I was told this was kosher as the Radio Shack meter reads low. Last edited by Dr. Spankenstein; 08-27-09 at 03:40 PM.. | ||||
| | #22 | |||||
If your system happened to output a lot of energy below 30Hz, then this wouldn't be considered in the levels setup since the low cut of the test signal is at 30Hz. You can see the problem..... brucek | |||||
| | #23 | ||||
| Re: New sub, strange response... I honestly was not aware of the cutoffs for the band-limited pink noise. I am very new to ALL of this. I can't express how much I appreciate your and Wayne's help and suggestions, but now that I have been made aware of this shortcoming, what would be a suggested solution? | ||||
| | #24 | ||||
| Re: New sub, strange response... Well, it's not really a problem. The Check Levels routine attempts to set a decent level for output and input. If you get a result in the green then that's fine. When you examine the waterfall, it's very easy to look at slice #1 (of 30) and use the Left Panel 'Trace Offset' and 'Add Offset to Data' feature to position your response trace around the 75dB target and then generate an appropriate waterfall. brucek | ||||
| | #25 | ||||
| Re: New sub, strange response... Don't know if this will shed any light on my situation, but here are the graphs from the other night. The positions and orientations might not mean much and not all are posted here (to respect your bandwidth), but they are in order: 1.) Rear left corner-firing along long wall 2.) Rear left corner-firing into corner @ 45 degree 3.) Rear left corner-firing into rear wall from 24" away 4.) Rear left corner-firing 45 degrees into room 5.) Front right corner-firing 45 degrees into room 6.) Front right corner-firing across width of room 7.) Front right corner-firing into front wall 8.) Front right corner-firing into corner @ 45 degrees ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Two places I haven't tried are the front or rear center of room width and midway along a side wall (both because of current obstructions-couch and table. Here are the graphs I get from the main LP (utlilizing the right front corner firing 45 degress into room). Each one varies from the center position by a mere 8". In order they are Left, Center, Right: ![]() ![]() ![]() Again, it's strange that the target level is reading so high as I've taken great pains to calibrate to 75dB. Any comments or suggestions? | ||||
| Bookmarks |
| Tags |
| response..., strange, sub |
| Thread Tools | |
