| REW Forum Finally Some REW measurementsDiscuss Finally Some REW measurements in the Equalization | Calibration forum; Finally Some REW measurements Finally after about 2months of fighting with REW, thanks Brucek. I move the sub around to several places in the ... |
Views: 235 - Replies: 2
| Finally Some REW measurements Finally after about 2months of fighting with REW, thanks Brucek. I move the sub around to several places in the room, and found that over all the right front about 2ft from the front of the superchunks and 8inch from the front wall looks the best (smoothest) the others were all over the place. Let me know if anything can be improved, would the BFD help me out at all? Yellow is the right front and blue is the left front. I have the sub in the right front currently. | ||||
| | #2 | ||||
| Re: Finally Some REW measurements I probably wouldn't EQ those results - they seem pretty good. Your measurements are a bit high - it's always good to take your measurements with a 75dB target. I would say the blue waterfall is a bit better. Note that the waterfall plots should use the same axis as the response plots of vertical=45dB-105dB and horizontal=15hz-200hz. That way they're centered around 75dB and you can see the 45dB noise floor. brucek | ||||
| Bookmarks |
| Tags |
| finally, measurements |
| Thread Tools | |
