REW Forum
Measurements pictures
Discuss Measurements pictures in the Equalization | Calibration forum; Measurements pictures Hello, it's my first use of REW, i can't find a way to get a picture of a measurement to ...
Views: 247 - Replies: 3
Old 08-31-09, 02:14 PM   #1
Alias: Jean
Loc: france
User: #41381
Since: Aug 2009
  jean is offline
Hello,
it's my first use of REW, i can't find a way to get a picture of a measurement to send or print. I see many posted here, how do you do it?
Thanks in advance.
Jean
Old 08-31-09, 02:29 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Measurements pictures
Bottom left hand corner of you REW graph is a floppy icon.
Click it to save a jpg of the graph that is 800 bits wide suitable for posting.
For subwoofer plots, always use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW. Use a measurement start frequency of 0Hz and an end frequency of 200Hz. Use the appropriate target line that matches your crossover.
You require five posts before you can show jpgs, so go the post padding thread to create some dummy posts.
Old 08-31-09, 02:35 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Post padding thread
Make sure the jpg you save is no larger than 800 megapixels wide, which is the largest you can upload to a post.
Old 08-31-09, 02:48 PM   #4
Alias: Jean
Loc: france
User: #41381
Since: Aug 2009
  jean is offline
Thanks, it works fine.
measurements, pictures
