REW Forum
WinXP locks up running REW
Discuss WinXP locks up running REW in the Equalization | Calibration forum; WinXP locks up running REW Hey everyone, thanks in advance for your help. I'm running windows xp pro with sp3. I installed the most recent ...
Views: 164 - Replies: 7
Old 09-19-09, 10:04 AM   #1
Alias: akajester
User: #34809
Since: Mar 2009
  akajester is offline
Hey everyone, thanks in advance for your help. I'm running windows xp pro with sp3. I installed the most recent version of java available then installed REW. I can get into the program and have performed the soundcard calibration and even made a few initial graphs with my SPL.
However, REW seems to randomly hang the computer requiring a hard power cycle to function again. Anyone else experience this? Thanks! I hope to post some graphs soon!
-akajester
Old 09-19-09, 11:13 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: WinXP locks up running REW
I have to say I have never heard of REW hanging a computer....... Is there anything in the REW error file?
Old 09-19-09, 01:02 PM   #3
Alias: akajester
User: #34809
Since: Mar 2009
Thanks for the response Brucek. I don't see an error log file in the REW directory. Where would I find it? Thanks.
Old 09-20-09, 08:05 AM   #4
Alias: brucek
User: #6
  brucek is offline
The REW error log is located in your home directory. In XP it will usually be in c:\Documents and Settings\yourusername\
The error files are stored there and are called roomeq_wizard0.txt, roomeq_wizard1.txt, etc.....
You can open them with Notepad. There's a rotating list, so choose the one with the newest date.
Old 09-20-09, 08:41 AM   #5
Alias: akajester
User: #34809
Since: Mar 2009
I checked the logs and only two of the files show any errors. I wonder, if the computer completely locks up would it be able to log anything first? Let me know if these help. Thanks again for the excellent program and for providing support!
roomeq_wizard2.log.txt
roomeq_wizard3.log.txt
Old 09-20-09, 11:03 AM   #6
Alias: brucek
User: #6
  brucek is offline
Sorry, I don't get much from those error logs that point to a problem.
I would suspect it would be java problem, but you'll have to see if you can isolate what you're doing at the time it locks up. Hopefully, the action is consistent enough to narrow down.
I really have no other ideas, other than to point to the fact that we've never had anyone ever complain about this... there's something special about your machine.
Old 09-20-09, 12:02 PM   #7
Alias: akajester
User: #34809
Since: Mar 2009
The only thing consistent about the lockups are that they only happen right after running calibration or room tests. It always happens after that point, when it's building the graph.
I'll reinstall Java and see if that makes a difference. Thanks!
Old 09-20-09, 08:21 PM   #8
Alias: akajester
User: #34809
Since: Mar 2009
I uninstalled java and installed version 6.0, instead of 6u16. I also saw a bios and sound card driver update for my mobo, so I did that. I'll report back if the problem is solved. Thanks again for the great software, tutorials and excellent support!
locks, running, winxp
