REW Forum
macbook + alesis multimix 8 usb starting out
Discuss macbook + alesis multimix 8 usb starting out in the Equalization | Calibration forum; macbook + alesis multimix 8 usb starting out ok, when it comes to computers and stuff, im not stupid, but for some reason i've been having trouble getting ...
Views: 338 - Replies: 7
Old 09-20-09, 01:08 AM   #1
Alias: Andrew Russell
Loc: Illinois
User: #41754
Since: Sep 2009
  Andrewskaterrr is offline
ok, when it comes to computers and stuff, im not stupid, but for some reason i've been having trouble getting REW to work
this is what i have set up
macbook -> alesis multimix 8 usb via usb -> control room out going to amp and then to speakers
i just bought the dbx rta mic and have that hooked up
when i run the test i get no signal
1. yes i have my settings on usb output and input
2. phantom power is on
3. when i tap on the mic i can hear it through the speakers
4. if i turn the mic up i get feedback
5. mic is positioned where my head is theoretically
6. i have the calibration file for my mic loaded to the "soundcard"
7. spl meter cal file is in 'mic/meter'
any ideas why im getting no input?
and also, where do i plug my spl meter in? the rca "two track" input? i get feedback there too
Old 09-20-09, 01:21 AM   #2
Loc: Illinois
User: #41754
Since: Sep 2009
Re: macbook + alesis multimix 8 usb starting out
ok the problem is REW is not registering my usb input. garage band does and everything else, except REW
Old 09-20-09, 02:05 AM   #3
Loc: Illinois
User: #41754
Since: Sep 2009
oh and im running snow leopard 10.6
Old 09-20-09, 08:10 AM   #4
Alias: brucek
User: #6
  brucek is online now
You have 'monitor' mode on in your soundcard - it must be off to run REW.
Did you start with the soundcard calibration routine (required). If so, did the routine work fine and create a proper calibration file that you then tested witha loopback cable for accuracy?
Old 09-20-09, 01:13 PM   #5
Loc: Illinois
User: #41754
Since: Sep 2009
i don't have a monitor mode on/off on my sound card. im using my alesis multimix 8 via usb for ins/outs. i don't know how i would set it up with the alesis
Old 09-20-09, 02:59 PM   #6
Alias: brucek
User: #6
I realize you're using the alesis - I call that a soundcard.
When you hear the mic as you speak into it, it means monitor is on. The end result is that the Playback Mixer in Windows has line-in enabled. Only the Record Mixer should have line-in enabled when using REW. You can check that and disable it directly in Widows if your Alesis doesn't have a specific monitor mode (although all soundcards do have it so that people can listen to CD's as they record them)...
Old 09-20-09, 03:13 PM   #7
Loc: Illinois
User: #41754
Since: Sep 2009
Ok, just making sure that's what you meant. The thing is I'm using mac osx snow leopard. When I turn the "control room send" off it doesn't send any signal at all to the computer. I'll try to post a picture when I get home
Posted via Mobile Device
Old 09-20-09, 04:37 PM   #8
Loc: Illinois
User: #41754
Since: Sep 2009
ok here's what it look like
i have the 'control room out' 1/4'' plugs going to my amp
at all times the mic goes through my speakers unless i hit off the 'mix to control room' button
any ideas
Last edited by Andrewskaterrr; 09-20-09 at 04:38 PM.. Reason: pictures in wrong order
alesis, dbx, macbook, mic, multimix, rew, usb
