REW Forum
So what's next?
Discuss So what's next? in the Equalization | Calibration forum; So what's next? I apologize if this information is somewhere else... I've looked and read lots of information but haven't really seen these ...
Views: 261 - Replies: 2
Old 09-21-09, 03:28 PM   #1
Silver Supporter
Alias: Bruce
Loc: Charlotte, NC
User: #13727
Since: Nov 2007
  Bruce Fisher is offline
So what's next?
I apologize if this information is somewhere else... I've looked and read lots of information but haven't really seen these questions answered.
I used REW and adjusted/calibrated a BFD1124 to improve my subwoofer by eliminating 1 big and 1 modest peak. I have a good graph with a house curve that sounds very very good to me... I'm very pleased with the results and thank everyone that spent so much time putting this together and explaining and documenting and answering questions on the forum.
What I'm wondering is:
- how do I use REW to help me adjust the subwoofer phase? Do I simply take lots of graphs adjusting the phase 10-15 degrees each time and pick the one with the best curve? Or is there something else I should do?
- how do I use REW (waterfall graphs?) to determine how much more room treatments I need? Or where to put them? I read the waterfall thread but still don't know how to determine this.
- My speakers (Emotiva 6.3s) have toggles on the back for +/- 2 (or off) for midbass, treble, and has a boundary compensation switch. To use REW, do I just run several tests in various positions and look for the chart that's smoothest?
Many thanks!
Old 09-21-09, 07:08 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: So what's next?
You use the RTA feature of REW and adjust the phase while watching the dynamic graph move as you adjust.
Follow the info below on using the RTA:
To use the RTA feature of REW, you must first setup the levels as if you were about to make a standard response measurement.
This involves running the Check Levels routine for the mic at the listening position to 75dB and the Calibrate routine. You can even run a measure to have a reference.
Then, select the Spectrum tab in REW and setup the controls as shown in the picture below.
Then, select the REW Generator and select Pink PN and start the signal using the play button.
Press the Red record button on the Spectrum page.
You can monitor your Input Level on the Spectrum page in the bottom left hand corner.
If it reads clip at any time (if you're moving the mic around when using the RTA), then simply turn down the REW input level a bit.
Below shows a response measure I took (that gets transferred to the RTA graph), and the black line is the RTA itself. You can then adjust the phase control at this point while watching for the best response.
The waterfall will show how long a signal persists and rings out over the bandwidth chosen (usually 0-200Hz). Treatment isn't too useful below ~100Hz, but you would be looking to reduce the ringing as much as possible.
Old 09-21-09, 10:36 PM   #3
Silver Supporter
Alias: Bruce
Loc: Charlotte, NC
User: #13727
Since: Nov 2007
Re: So what's next?
great stuff - thanks for the info - I'll have to give it a shot this weekend.
next?, what's
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
