First timer questions. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss First timer questions. in the Subwoofer Equalization | Calibration forum; First timer questions. I've been lurking around here for a couple days now reading as much as possible, very enlightening. There is still ...
Old 02-14-07, 03:33 PM   #1 (Link)
New Member
Alias: chris
Loc: MI
User: #6515
rcchris is offline
I've been lurking around here for a couple days now reading as much as possible, very enlightening. There is still alot that I do not understand so hence this post of noob questions. I have a Denon 2805 arriving Friday. I do not have a BFD. The Denon has an auto eq which I don't put much faith in, but it has, I believe, an eight band equlizer for each channel that can manually be adjusted. I know that this is not close to the tweaking that could be done via the BFD but it is all that I will have for a while. My sub is a B&W ASW 600 .
Questions:
1. Will it be worth my while to use the Denon eq manually, based on REW results.
2. Before I run REW do I need to set distances and levels of my speakers in the 2805.
3. Should I use different eq settings for different inputs e.g. music vs HT.
4. Is it correct that I should strive for a flat response from my sub and a house curve for FR,FL with sub.
5. What kind of curve for 5.1 movies.
Thank you,
Chris
Old 02-14-07, 04:15 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: First timer questions.
When I had my 3805 and 3806, the Denon EQ did effect my sub response, although I had the mains set to small and the x-over set to 80Hz... it dropped my LFE response by 6db or so. So I decided not to use it.
You definitely need to run the Auto-Setup in the Denon before doing anything else. Then you can run REW and look at your sub response.
As far as music, HT, house curves, etc... all of that is totally up to your preferences. You can try different curves and see what you prefer.
Welcome to the Shack!
Sonnie
Old 02-14-07, 04:34 PM   #3 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Hi Chris, welcome! If I am not mistaken, the Denon only eq's down to 63hz. That can have some effect on the bass above that level. You could play around with sub placement. Usually a corner not close to an opening will allow for room gain. Just about every home I have lived in had a big room boost at about 50 Hz. Before I got a BFD, I found an eq that went to 20 Hz at a pawn shop. I think if you will use the Room EQ Wizard, you can tell how much equalization you might need.
I now have the new Denon 2807 that has the Audessey MultiEQ built in. It works great. I hope to have some pics and graphs up in the near future. Keep reading and keep asking questions. Let us know how it goes. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 02-15-07, 02:04 AM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
That is the center frequency, but for some reason it has a extremely wide bandwidth. My response was down 4db (I stand corrected, it was 4.1db, not 6db as stated in my previous post) from 15-30Hz using the Audyssey MultEQ. There could be something else going on, but I know whenever I turned the MultEQ off... the response returned to normal... and 4db may not seem like much, but I could tell a difference.
Here's the response comparison:
Red: Normal
Green: MultEQ
Here's that thread discussing it.
Otherwise, it does a splendid job.
Sonnie
Old 02-15-07, 10:06 AM   #5 (Link)
Shack Moderator
Alias: Dr Doan
User: #2314
Since: Aug 2006
drdoan is offline
I think the Audessey MultiEQ goes all the way down, but, the non-Audessey Denon's don't as far as I know. I am not real sure of this. I know Yammie's YPAO stops at 63HZ, tho. If I understand the Audessey website, it is capable of corrections at just about any audible freq. I do know this; when I use it on my system, it makes a very noticable improvement, especially when listeneing off center. Dennis
L Dennis Doan, DC
IT'S THE NERVE!
www.drdoan.com
Direct TV DVR HD
Similar Threads
New sub, some same old questions Mark Holmes REW Forum 6 10-24-06 10:58 AM
BFD Questions! House Curve Questions! RyanJNielson BFD Forum 5 09-05-06 09:34 AM
Anyone with watercooling questions...? khellandros66 Computers | Games | HTPC | Digital Devices 18 08-29-06 07:31 AM
General questions JCD DIY Speakers 3 07-07-06 11:52 PM
BFD Questions gacole2000 BFD Forum 16 06-02-06 07:00 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
