| REW Forum Getting ready for bass trapsDiscuss Getting ready for bass traps in the Equalization | Calibration forum; Getting ready for bass traps I am making bass traps for my room so I would like to test the room before I install these ... |
Views: 196 - Replies: 4
| Getting ready for bass traps I am making bass traps for my room so I would like to test the room before I install these traps. I have the latest version of room wizard installed. Do I need to buy a hardware eq device as listed under equilisers?? ![]() ![]() | ||||
| | #2 | ||||
| re: Getting ready for bass traps Not yet, First follow the instructions here and make sure you use the line in on your sound card not the mic in. Do you have an SPL meter? Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| re: Getting ready for bass traps I have a radio shack digital meter. My equipment setup is 2 KRK nearfield monitors. I KRK Sub. Rme fireface 800 A number of microphones. Gemini MII. Pearlman, Shure. No sound card Firewire Interface with asio drivers. | ||||
| | #4 | ||||
| re: Getting ready for bass traps Since you have the RS meter, the only other thing you need is a soundcard with line inputs and outputs that's compatible with your OS. Since you're doing bass traps, you'll want to run your graphs up to 500 Hz or so look at the waterfall graphs, which show the rate of signal decay. Regards, Wayne | ||||
| | #5 | ||||||
| re: Getting ready for bass traps Quote:
brucek | ||||||
