| REW Forum Using REW to setup B&K PEQ and notch filterDiscuss Using REW to setup B&K PEQ and notch filter in the Equalization | Calibration forum; Using REW to setup B&K PEQ and notch filter I watched Transformers this morning and decided I wanted more infrasonics. So I spent several hours tweaking the shelf, notch ... |
Views: 449 - Replies: 29
| | #26 | ||||
| Re: Using REW to setup B&K PEQ and notch filter I watched Transformers this morning and decided I wanted more infrasonics. So I spent several hours tweaking the shelf, notch and crossover filters, as well as the relative gain on the two subs to achieve that, as well as an even smoother response. New settings are +6dB below 40Hz for the shelf, -9dB at 62Hz for the notch, and a crossover of 60Hz. Here is the response with the mains playing: ![]() ---------------- And here it is for subs only: ![]() | ||||
| | #27 | |||||
| Re: Using REW to setup B&K PEQ and notch filter Quote:
Regards, Wayne | |||||
| | #29 | |||||
What should I be doing? Here is a waterfall plot of the setup as it sits currently: ![]() | |||||
| | #30 | |||||
The more plots I do, the more I think this dip at around 100Hz be a real cancellation effect. I'm not sure why it seemed to be correlated with the notch filter when I first noticed it (doesn't seem to be now), but if it indeed is related to the filter then whatever detrimental effect this may represent is more than offset by the benefit I'm getting from engaging the filter. | |||||
