| REW Forum REW repeatability?Discuss REW repeatability? in the Equalization | Calibration forum; REW repeatability? elee532 wrote:
I gave this a try on another computer... 0 to 200Hz sweep using 128, 256k, 512k, and 1M ... |
Views: 659 - Replies: 36
| | #1 | |||||
| REW repeatability? Quote:
Good job finding out about the measuring problem. Thanks, Robert | |||||
| | #2 | |||||
| Re: Comments on my first measurements? Quote:
Regards, Wayne | |||||
| | #3 | ||||
| Re: Comments on my first measurements? Well, I feel that if you measure the driver and the spl of the signal- at the driver is 75dB, you are going to get a different reading concerning room gain than if you measure listening position of 75dB. It has to make a difference. My room is 4800 cf. When I put the mic at 1/2" from the cone and point the mic directly at the cone, I get completely different graphs. I am, at that point measuring the driver itself. As I back the mic up so it won't hit the cone, my graphs change shape and then I start getting room interactions, but nothing like a slope going up below the tuning. For instance, At the GTG, a few months back, we used 2 different microphones at 2 different locations and got pretty much the same looking measurements. The room was causing some differences, but a roll off at 20- 25 Hz measure at 3 feet for one particular sub did not result in a graph at the opposite wall measure showing a rise beyond the tuning. The graphs just showed less rolloff per octave. In the graph from the previous post, I would almost certainly think that the measures were in error due to the fact that they look so different and are from the same position. I need to go, but I need to get a handle on this, so please bare with me. Thanks, Robert Last edited by robertcharles123; 10-01-09 at 02:04 PM.. | ||||
| | #4 | ||||
| Re: Comments on my first measurements? ![]() This was my first measure at listening position. I know it is not really scaled correctly, but disregarding that, if I accepted the response measure as "good", I would be seeing extension down to 2Hz. I did not believe this, so I kept measuring and checking the adjustments and calibrations. Now my graphs are different again, but very closely resemble what was modeled when designing the system. ![]() Here are one driver and top and bottom passives measured 1/2 inch from the cones. My newest graphs at listening position are resembling this general shape-give or take, but no upslope below the cabinet tuning. In order for me to believe that that can occur, I would have to put my sub in the room where this occurs and use it against the sub that is tested there now and run multipleREW setups on different computers to see if it is a computing error or measuring error or actual reality. I have yet to experience it myself and I wat to do just that. Any better? I want to understand How this works and do it correctly. I want accurate and repeatable results that can be done by anyone and the result remains the same. Thanks, ' Robert ![]() This is a measure of my subs at listening position-basically in the center of the room. I could and can't repeat this measure now, although I was getting this measure or something like it for quite some time. | ||||
| | #5 | ||||||
| Re: REW repeatability? Quote:
Regards, Wayne | ||||||
| | #6 | |||||||
Regards, Wayne | |||||||
| | #7 | |||||
I will get connected tonight and run some stuff and see if I can gleen some knowledge from a few guys here to get some descent results. | |||||
| | #9 | |||||
This is of course assuming that all of the calibration was done correctly. I personally prefer to run without calibration files (although I'll post my results with the calibration files in place) because I can learn to recognize the behavior of the microphone and distinguish it from the behavior of the system I'm trying to measure. Also, the purpose of the frequency response graph is not to tell you that your system sounds good. There are all sorts of ways to have a system that measures flat, but that doesn't mean all those ways are going to sound good. It's also interesting to observe just how much low frequency extension is overstated in its effects on perceived sound quality. And lastly, the room gain of every room is very different and is a function of the room volume, how rigid the walls are and how well sealed the room is. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | |||||
| | #10 | |||||
![]() Red line is listening position with no mic cal file. Blue line is listening position with mic cal file I am running my cabs through a crown ITech 8000. It has a built in HPF at 8 Hz. It is not defeatable. I am getting a couple of FACE amps soon, and I will measure with them and see if any changes occur. Any thoughts? Here are my LFE cabs. ![]() ![]() Last edited by robertcharles123; 10-02-09 at 01:07 AM.. | |||||
| | #11 | |||||
I've been trying to educate people on this, but I don't think I've been able to word it so succinctly.20db of calibration for your mic/meter plus another couple of db from your soundcard added to 45 or 50db of low frequency background noise = Voila! 75-80db of apparent <15hz response and..."Wow my ported 150w 12" White van sub is really digging deep!" | |||||
| | #12 | ||||
| Re: REW repeatability? You are 10dB down by 34Hz...I wouldn't worry about the 8Hz highpass right now. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #13 | |||||
![]() Only that I’m confused about the repeatability question. Are you telling us that these readings were taken in the same location, with the same sub? I would have a hard time believing that... ![]() ![]() Regards, Wayne | |||||
| | #14 | ||||
| Re: REW repeatability? Robert, How about a little more background on these measurements? Just the LMS subs, or with mains, or other JBL subs? What crossover freq? Any EQ enabled in those Itech's or in your processor? Audyssey? What microphone do you have? I'd highly suggest getting one of the calibrated ones available here from Cross Spectrum labs if you haven't already for about $90. What sound card? The 35hz and over response is not too bad with just the 90hz dip. The action in the 16-32hz octave is bad though and this is where those big subs should be at their best. You drop some 20db from 38hz to 28hz and then staying at 10db or more lower overall level than the 80-35hz range. This is a strange variation in response to me. Almost like you have some cancellation, or EQ going on. | ||||
| | #15 | ||||
| Re: REW repeatability? Those measures are taken at listening position with the soundcard plugged directly into the amplifier. Nothin else in the mix at that point- just the Itech8000 to the cabs. What do you think could be the problem? | ||||
| | #17 | ||||
| Re: REW repeatability? I honestly do not think my computer is powerfl enough to handle the setup. It seems like it glitches at times when it is sweeping. That is the reason why I want to use another person's computer who has good repeatable measurements in order to compare graphs. I will say, regardless what these graphs say at this point, I have never heard or felt better bass in a home environment or theater for that matter, so I am satisfied either way. I just want to make sure I am getting the most out of the setup and learn to use these programs correctly. Any ideas? | ||||
| | #18 | |||||
That is what I have been trying to tell you. I got some really good measures that were relartively flat at one time, only to lose the use of the program to a virus and now you see what I get. I am saying that all of those graphs are from the same spot where my head would be. the mic is on a stand and held in the same spot throughout. Any thoughts as what to do to get the measurements to be reasonable and believable? | |||||
| | #20 | ||||
| Re: REW repeatability? The only time I've seen response differences that drastic has been when people moved the sub to a different location. If everything is sounding good to you, I'd sure be questioning what your getting from REW. You might download some sine waves from the BFD Guide for 20 Hz and 40 Hz. If you register a 10-12 dB difference between them that would confirm whether or not REW is in the ball park. Regards, Wayne | ||||
| | #21 | ||||
| Re: REW repeatability? Cool. There really is no moving my cabinets. They require lots of planning in order to get from one point to another. I was thinking of moving them a little, but other things are going to be in the way, so there they stay. I will try what you said. I might need a little coaching. Thanks. Thanks, Robert | ||||
| | #22 | ||||
| Re: REW repeatability? Try turning off your wi-fi when taking measurements...or anything else that does automatic stuff in the background. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #23 | ||||
| Re: REW repeatability? I turned off the internet and the connection last night for the last measures. Funny you say that about the noise. I had a lot of noticeable noise when the rca cable was plugged in, I took it out and used another, I am going to have to use a good plug and see what the story turns out to be. I will try that later on. | ||||
| | #24 | ||||
| Re: REW repeatability? So I should play a 20 Hz sine wave and get a SPL. Then, measure a 40 Hz sine wave and get a SPL. No changes should be made in the setup from measure to measure-whatsoever? I will do this. What about the tone generator in the REW? | ||||
| | #25 | |||||
You know, I bought the crowns as b stock. They might have a filter turned on somewhere, I just do not know how to tell. I am going to run another amp to the cabs and see what happens. Sooooon! | |||||
