REW Forum
REW and Windows 7
Discuss REW and Windows 7 in the Equalization | Calibration forum; REW and Windows 7 I am getting an error message upon install, namely Java VM needs to be installed. The latest version is in ...
Views: 413 - Replies: 15
Old 10-03-09, 10:22 PM   #1
Alias: Nicholas Bedworth
Loc: Hawaii
User: #42864
Since: Oct 2009
  Nicholas Bedworth is offline
REW and Windows 7
I am getting an error message upon install, namely Java VM needs to be installed. The latest version is in fact installed, and I did an uninstall, download and reinstall of the JVM. No luck.
Control panel says I have the Java 6 update 16, 64 bit, along with the Java SE Development Kit 6 update.
I also tried running REW in Vista compatability mode, run as administrator, no joy.
Got any ideas?
On my other machine, Vista SP3, no problems, seems to have found my M-Audio FW 410 OK.. waiting for the Behringer microphone to arrive.
Old 10-03-09, 11:03 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: REW and Windows 7
I don't remember anyone trying REW with Windows 7 yet, so you may be the first. I thought it would work fine, since it's so close to Vista......
Old 10-04-09, 08:24 AM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
You can try using the Linux jar files - they are what the Windows installer wraps in an exe, just follow the Linux installtion instructions.
Old 10-05-09, 07:07 AM   #4
Alias: al
Loc: london
User: #35064
Since: Mar 2009
  minaximal is offline
I have been using REW with java 6 update 16, in windows 7 with no problems, but i also only use 32bit, i seem to remember i tried java's win 7 beta version, but it wasn't very stable at the time although that was a few months ago, so far i use all vista drivers and software with no problems.
maybe look for java win 7 version?
Old 10-05-09, 01:46 PM   #5
Alias: Bowed
Loc: Suwanee, GA
User: #42431
Since: Sep 2009
  Bowedtoothdoc is offline
I am using REW with Windows 7RC (64bit) with no issues. I do remember having to install both 32bit and 64bit versions of Java.
Old 10-28-09, 01:43 AM   #6
Alias: jim
Loc: Scarborough Maine
User: #4625
Since: Dec 2006
  nerdful1 is offline
I'm running rew in the w7 release client, and except for puzzling things likely of my own doings, it runs well.
The windows 7 RC, which is free to use till spring, is the full blown, not crippled versions like Home Premium and the like, maybe they are missing things.
'Plugging the analog hole' stuff made me waste hours on the Vista beta regarding audio connectivity.
I'm glad to see Linux file for REW, so won't likely be using it on Windows much.
Old 10-28-09, 02:03 AM   #7
Alias: Matt
User: #6799
  Chester is online now
im rockin 7; using java 32 bit (on a 64 bit computer... that means it goes twice as fast right ;p)
Old 10-28-09, 06:16 AM   #8
Alias: David
Mika75's Avatar
Loc: Victoria, Australia
User: #33426
Since: Feb 2009
  Mika75 is offline
jhnsmith978 wrote: View Post
Is it worthy to move from window vista to window 7..
Windows 7 Performance Guide @ Anandtech
Pre: TAS Processor Eq: DCX 2496 Power: Behringer A500, Ebony 290w x4 Source: Sony DVD Front: Tag 2.6 Center: n/a Rear: Yamaha NS-225 Subs: Whise 624
Old 10-28-09, 09:55 AM   #9
Alias: Matt
User: #6799
I love windows 7 compared to vista and however you should go to a store or friends place and check it out first (or at least look at some screen shots online); some people do not like it, though
Old 10-28-09, 10:30 AM   #10
Alias: Bob_99
Bob_99's Avatar
Loc: New Hampshire
User: #460
  Bob_99 is offline
I think anyone who had to tolerate Vista should get a free copy of Windows 7. Vista has to be the worst OS I've ever used and I have used a lot of them over the past 30 plus years. The fact that Microsoft is not even offering a discount to users of Vista has dropped my opinion of them even lower than it was.
Bob
"There is always hope, even if it is just a fool's hope."
Old 10-28-09, 11:21 AM   #11
Alias: brucek
User: #6
  brucek is offline
I really like Vista. It's one of the best operating systems I've ever used - and I too have used them all - starting from DOS.
Old 10-28-09, 01:35 PM   #12
Alias: Bob_99
Bob_99's Avatar
Loc: New Hampshire
User: #460
  Bob_99 is offline
brucek wrote: View Post
On a "PC" (S-100 system), I started with PC/M but in any case, your answer made me chuckle. I guess it really is different strokes for different folks not that I would ever imagine my preferences to be a baseline for anything. Needless to say, I jumped on 7.
Thanks.
Bob
Old 10-28-09, 02:01 PM   #13
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Is windows 7 an "upgrade" to Vista or do you basically reinstall on a clean hard drive?
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 10-28-09, 04:07 PM   #14
Alias: Bob_99
Bob_99's Avatar
Loc: New Hampshire
User: #460
  Bob_99 is offline
tonyvdb wrote: View Post
I upgraded from Vista although some people like to do a clean install since Windows tends to get very cluttered after a lot of use. I have not seen any reference to 'upgrade' versions of Window 7 versus the full install version so my assumption was that you could do either when you purchase a license. I could be wrong. I also believe other versions of windows require a clean install and I recall Microsoft having a chart on their web site if you can decipher it (very confusing imo)
Bob
Old 10-30-09, 10:43 PM   #15
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
If you get the upgrade version of Windows 7 then you have to have another OS installed first. There is a hack to that however to install the upgrade version on a bare drive, but it's not straight forward (and it's illegal).
The full version is a little more expensive and allows you to install on an unformatted drive, a formatted but blank drive, formatted with an OS installed drive (as upgrade) or a formatted with OS installed with the option to reformat.
I've been running Windows 7 since last winter as my primary OS and didn't encounter any problems at all. I recently got the Steve Balmer Edition of Windows 7 Ultimate but haven't installed it yet. Before that I had Windows XP Professional. WMP 12 on Win7 works with my PS3 and Denon 4306 to stream media. It didn't with WMP 11 on XP no matter what I tried.
Old 10-31-09, 01:23 AM   #16
Alias: jim
User: #4625
Since: Dec 2006
  nerdful1 is offline
heh " a little more expensive"
Just had to jump in.
I see that there is a Linux Version of REW, and whoever made that up should be thrown a few perfect home built subs as a gift.
Before spending any money on Windows, that you could use to put to your audio, let me take on the task of "REW on Linux Made Easy". REW on an older box, likely running much more efficiently than any vista. For our group.
I am so Impressed by REW, the microphone eggspurts, and other things learned here.
I want you to challenge me:
In the next month, I'll post here well, maybe some linux vs w7 thread, someone start it...
I will this week take the linux version of REW and
1. Post it as a requested package to be tested on my favorite Linux Distro PCLinuxOS.
We (PCLinuxOS) users are not allowed to mess up our machines with unapproved files, but there is a sub group into that, and being linux, we just build a bunch of sacrificial machines to play on.
2. install it in my PCLinuxOS sacrificial machine. If it is easy I will make what is called a remaster cd and make it available here as a download.
So you would have a live cd with rew on it.
If your REW 'puter has a bit of hard drive free, believe me, you can have two machines in one, the second better than a MAC.
W7 is good, for now, I have many of the mailed to me boxes and trash to recycle from the w7 disks sent me and all the plastic cases etc. Linux is so much greener.
But so I am not bashed here, yes w7 works great, I am dismayed that vista users must upgrade to get a stable OS? Will a Vista user ever get theirs patched like XP? I'm keeping my paid for XP boxes as long as MS supports it.
From what i know MS wants to get people into a 2 year upgrade now.
And PCLOS runs great on a customer's MACIntel desktop.
windows
