| REW Forum REW and Digidesigns Digi002Discuss REW and Digidesigns Digi002 in the Equalization | Calibration forum; REW and Digidesigns Digi002 REW is outputting through 002 but does not recognize the input. The 002 appears as default audio devise on Audi/Midi ... |
Views: 114 - Replies: 4
| REW and Digidesigns Digi002 REW is outputting through 002 but does not recognize the input. The 002 appears as default audio devise on Audi/Midi setup yet the REW refuses to see it, is the REW not compatible with the 002 for some reason? I checked to make sure in system preferences that I have input from the mic via the 002, everything fine there. I'm using a Power Mag G5 DP 2.0 Ghz with 6.5 GB ram. Just yesterday I used the 002 to do some room calibration using the IK Multimedia ARC system and got the worst results I could have imagined. Any help would be appreciated. | ||||
| | #2 | |||||
| Re: REW and Digidesigns Digi002 Quote:
brucek | |||||
| | #4 | ||||
| Re: REW and Digidesigns Digi002 I'm not that familiar with Mac, but I don't believe the Power Mac is an Intel (which REW also requires). Either way, I don't know if you'll be able to use one soundcard for input and another for output and get a good calibration file.. brucek | ||||
| Bookmarks |
| Tags |
| digi002, digidesigns |
| Thread Tools | |
