REW Forum
New sub, some same old questions
Discuss New sub, some same old questions in the Equalization | Calibration forum; New sub, some same old questions I would appreciate a bit of help here. I have a new DIY sealed sub that I am integrating into ...
Views: 635 - Replies: 6
Old 10-23-06, 05:31 PM   #1
Alias: Mark Holmes
Loc: Alpharetta, GA
User: #3050
Since: Oct 2006
  Mark Holmes is offline
I have a new DIY sealed sub that I am integrating into my system. I am using a Bassis and a BFD.
What I am trying to get is a response curve flat to 10 Hz. The Bassis is incredible in boosting the low end. And I am working on the BFD to smooth things out. I am almost there but...
First question. What does a driver sound like when you reach excursion limits?
Next, Why does it seem that when I limit frequencies above 20 Hz that the output below 20 Hz increases?
Finally, I have a 4 year old Rat Shack meter, and am still confused as to what correction factors I should be using below 20 Hz.
Down around 10 Hz, I mostly hear things shaking in the room.
Thanks,
Old 10-23-06, 05:47 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: New sub, some same old questions
There are three different Radio Shack meters and the model numbers with calibration files are here.
Old 10-23-06, 09:48 PM   #3
Alias: Mark Holmes
Loc: Alpharetta, GA
User: #3050
Since: Oct 2006
Oops, I should have said that I had the old style 33-2050 meter. Sorry.
Is there any accurate data below 16 Hz. I get really significant output down low. If I could figure out how to save the spreadsheet in a small enough format, Iwould post my results. But if the correction factor at 16 Hz is correct, I am getting astonishing output down low. And I need to rethink the boost I am applying.
I really may be flat to 10 Hz.
Thanks,
Mark
Old 10-23-06, 11:21 PM   #4
Alias: brucek
User: #6
The url in my post above shows where to get the calibration file for that meter. It goes to 10hz..
Old 10-24-06, 07:24 AM   #5
Alias: Mark Holmes
Loc: Alpharetta, GA
User: #3050
Since: Oct 2006
Thanks Bruce,
I was looking at the spreadsheet which only went down to 16 Hz. What am I supposed to do with the .cal file?
Old 10-24-06, 09:42 AM   #6
Alias: brucek
User: #6
Most people around here use a software program called REW. It is free and downloadable. REW uses the .cal files.
But you can also modify the Excel file if you are inclined. The .cal file is a simple text file that can be read with Windows Notepad. The compensation values could be used in the excel file to extend it down to 10Hz. Using the same 1/6th octave spacing as the existing excel chart would add the 4 values below 16Hz(15.874) of :
14Hz(14.14) = -18.61 dB
13Hz(12.6) = -20.13 dB
11Hz(11.22) = -24.15 dB
10Hz(10.00) = -27.00 dB
I would recommend taking a look at REW...
Old 10-24-06, 11:58 AM   #7
Alias: Mark Holmes
Loc: Alpharetta, GA
User: #3050
Since: Oct 2006
Thanks, sorry for bing so uninformed...
Wow, 27 dB at 10 Hz... That means I am seeing over 100 dB at 10 Hz! It is kinda hard to believe I am getting that much output down that low.
