REW Forum
FBQ problems
Discuss FBQ problems in the Equalization | Calibration forum; FBQ problems I finally got the USB soundblaster up and running, calibrated everything and ran some sweeps. Everything works fine until I ...
Views: 190 - Replies: 13
Old 10-10-09, 01:02 AM   #1
Alias: rickp
Loc: Montgomery, Al.
User: #15476
Since: Jan 2008
  rickp is offline
FBQ problems
I finally got the USB soundblaster up and running, calibrated everything and ran some sweeps. Everything works fine until I enter filters into the FBQ then I get no sound on the next sweep and the only remedy is removing the filters or hitting the bypass button. What am I not doing right?
Old 10-10-09, 08:49 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: FBQ problems
For subwoofer graphs, please use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW.
What method are you using to enter your filters?
Old 10-10-09, 09:21 AM   #3
Alias: rickp
User: #15476
Since: Jan 2008
  rickp is offline
Re: FBQ problems
Push the PEQ button
turned on channel ( have tried 1,2 ect and 19,20 ect)
Push FREQ button and adjust
Push GAIN button and adjust
Push BANDWIDTH button and adjust
Push PEQ button and run REW
Old 10-10-09, 09:31 AM   #4
Alias: rickp
User: #15476
Since: Jan 2008
  rickp is offline
Re: FBQ problems
How is this?
Old 10-10-09, 09:45 AM   #5
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: FBQ problems
Scaling is good - is that your baseline or equalized graph?
Old 10-10-09, 09:59 AM   #6
Alias: rickp
User: #15476
Since: Jan 2008
  rickp is offline
Re: FBQ problems
Its the base line, when I add filters no sound comes out from the sweep.
Old 10-10-09, 10:00 AM   #7
Alias: brucek
User: #6
  brucek is offline
Re: FBQ problems
Push the PEQ button
Be sure all the filters in the channel are set to parametric.
Remove all the filters and then play a tone with REW's Signal Generator (i.e. 50Hz) and have the tone coming through your sub (low volume). Then play with a single filter at 50Hz on the FBQ while the tone is playing to see what happens......
Old 10-10-09, 11:10 AM   #8
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: FBQ problems
rickp wrote: View Post
Is it possible that you loaded the EQ up with a bunch of filters with extreme cuts, to the point that there is no longer any signal left to pass through?
Old 10-10-09, 12:10 PM   #9
Alias: rickp
User: #15476
Since: Jan 2008
  rickp is offline
Re: FBQ problems
I just figured it out I think, in order to save the setting the unit has to be powered off then on again
Old 10-10-09, 01:08 PM   #10
Alias: robcart65
Loc: robcart65
User: #43179
Since: Oct 2009
  robcart65 is offline
Re: FBQ problems
That's great
Old 10-21-09, 12:08 PM   #11
New Member
Alias: todd
Loc: rochester,ny
User: #23497
Since: Jul 2008
  sandworms is offline
Re: FBQ problems
what sub do you have?
Old 10-22-09, 07:09 AM   #12
Alias: rickp
User: #15476
Since: Jan 2008
  rickp is offline
Re: FBQ problems
Its an IB set up with 4-18" FiCars and a EP4000 with a FBQ used for movies only. I also have 2-15" sealed boxs in the rear corners for music only. The main speakers have 2 15" woofers per side. The graph is of the IB only I haven't had the time to set up the rears and intagrate the main woofs yet.
Old 10-22-09, 07:21 AM   #13
Alias: rickp
User: #15476
Since: Jan 2008
  rickp is offline
Re: FBQ problems
The waterfall plot is not looking so good from 15-80hz, even at 500ms never touches the floor. all the room treatments are in except for the carpet and 2 2'x7'x2" 703 traps on the ceiling between the screen and the projector. I have a 2x3' area behind the main speakers that has a 24" floor to ceiling corner traps, I wonder if I bought some more bags if insulation and stacked them in front of the corner traps behind the speakers if that would help? how much does carpet help with ringing bass?
Old 10-22-09, 08:49 AM   #14
Alias: brucek
User: #6
  brucek is offline
Re: FBQ problems
Best to ask acoustic related questions in the acoustics section of the forum. They're more equipped there to follow up on your questions..
problems
