| REW Forum What do I do with this?Discuss What do I do with this? in the Equalization | Calibration forum; What do I do with this? Thanks to the members of this forum, my subwoofer measurements are working and the setup has come a long way. ... |
Views: 176 - Replies: 5
| What do I do with this? Thanks to the members of this forum, my subwoofer measurements are working and the setup has come a long way. I was able to identify a null at the listening position at 38Hz when the sub is placed along the left wall (the only place it can go and pass WAF), and subsequently fill it in reasonably well by integrating a second, small subwoofer next to the center channel. Feeling pretty good about that, I decided to take some full-range measurements to see what that looks like. Boy, did that open up a can of worms! Below is a graph of subs plus center channel from 15-20k (black) and the L+R mains (magenta). I also measured L and R separately and they both overlay onto the magenta L+R graph (data not shown). ![]() As you can see, my previously identified mode of 38-40Hz appears to also rear its ugly head at 10 times the frequency. I think I was happier when I was somewhat ignorant of the problem. I have known for some time that something was going on - just had never quantified it. So I played a 40Hz test tone and walked around the room with my SPL meter. There is a huge standing wave across the width of the entire room, with its null at the listening position, and a peak along each L/R wall. Spatially, it is one giant cosine wave with the left wall representing x=0 degrees and the right wall representing x=360 degrees. It doesn't matter where you stand in the length dimension - you can walk the length of the room in a straight line along the null or one of the peaks and the sound meter doesn't change. ![]() Last edited by Jarrod; 10-12-09 at 06:04 PM.. | ||||
| | #2 | ||||
| Re: What do I do with this? First of all can you redo the graph limits so they only show 20-200Hz this will help us see what is really going on. Dont worry too much about the graph above 2K as its not going to be very accurate unless your using the ECM8000 mic. There is a nasty dip at 400Hz what is going on there? I would be more concerned with that dip over the dip at 40Hz. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||||
| Re: What do I do with this? He has an ECM8000, Tony. ![]() Quote:
![]() Regards, Wayne | ||||||
| | #4 | |||||
| Re: What do I do with this? Tony: the 20-200 Hz graphs are posted in my other thread. As Wayne already pointed out, I'm using an ECM8000 with the ECM8000_CS.cal calibration from the download area. Quote:
What about diffusors? Is this hopeless? | |||||
| | #5 | ||||
| Re: What do I do with this? We're mainly EQ guys here. For questions on acoustical treatments, we have informed parties at separate Forum for that. Scroll down our main index page and you'll find it. ![]() Regards, Wayne | ||||
