| REW Forum Need new sound card?Discuss Need new sound card? in the Equalization | Calibration forum; Need new sound card? I have a "SoundMAX digital audio" sound card and cannot make it work. Will this card not work?
If not, ... |
Views: 222 - Replies: 9
| Need new sound card? I have a "SoundMAX digital audio" sound card and cannot make it work. Will this card not work? If not, I have been on Ebay and found Creative Audigy 2 NX external and Creative Live external. Will both of these work and are there other inexpensive external cards I should look at. Thanks Moto | ||||
| | #2 | ||||
| Re: Need new sound card? I have read that SoundMAX digital audio can be a problem, so you may indeed want to get a new soundcard. Basically, any inexpensive soundcard will work as long as it's duplex and has a line-in (not mic-in) and line-out. brucek | ||||
| | #4 | |||||
| Re: Need new sound card? Quote:
brucek | |||||
| | #5 | ||||
| Re: Need new sound card? oh ok, thats right. my soundcard has a internal mic preamp so i use this input for my mic. or is this not good for measuring with rew? sorry im new to this tool, thats why i have a lot of questions. g | ||||
| | #8 | ||||
| Re: Need new sound card? Wouldn't this be an issue for connecting the loopback for soundcard calibration? | ||||
| | #9 | |||||
It's certainly possible though to fabricate a resistive pad for the mic input to accomplish a more accurate calibration. I tested this on my XENYX mixer and found (as suspected) that the mic preamp had very little effect on the response already established with the line amp sections. Others have done this with their external soundcards with mic preamps and found similar results. brucek | |||||
| | #10 | |||||
