| REW Forum Help Understanding Signal Cal.Discuss Help Understanding Signal Cal. in the Equalization | Calibration forum; Help Understanding Signal Cal. Hey guys,
Here is my first test of Rew using standard laptop soundcard with the RS 4050 meter. I calibrated ... |
Views: 136 - Replies: 3
| Help Understanding Signal Cal. Hey guys, Here is my first test of Rew using standard laptop soundcard with the RS 4050 meter. I calibrated soundcard/spl meter and then i put pink noise in the system to -18db under speaker cal. but once i got my signals to ok and did my sweep it gave me a distortion alert. I read about this and it told me to lower my sweep volume which is default to -18dB. Well, I ended up having to lower this to -30dB before the distortion alert went away. So now, isnt my signal cal mest up if the -18dB calibration distorts? Because i had to record the sweep 12dB lower? Anyways some clearity on this would be great help. Here is the graph i did with the sweep calibrated to -18dB with a -30dB sweep. ![]() | ||||
| | #2 | |||||
| Re: Help Understanding Signal Cal. Quote:
brucek | |||||
| | #4 | |||||
Mic inputs usually enjoy a very limited bandwidth that is designed to comply with a narrow voice frequency range that a cheap microphone would supply. The port often supplies a 5 volts bias signal also. Note when posting graphs: For subwoofer plots, always use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW. Use a measurement start frequency of 0Hz and an end frequency of 200Hz with a 75dB target. Use the appropriate target line that matches your crossover. ![]() brucek | |||||
| Bookmarks |
| Tags |
| cal., signal, understanding |
| Thread Tools | |
