| REW Forum recommended USB microphone for REWDiscuss recommended USB microphone for REW in the Equalization | Calibration forum; recommended USB microphone for REW Hi, we are going to use REW to setup general PA and conference room audio systems. Our laptops have an ... |
Views: 290 - Replies: 16
| recommended USB microphone for REW Hi, we are going to use REW to setup general PA and conference room audio systems. Our laptops have an audio jack that is both input and output(lame!) depending on pc settings. Since we want to use the test patern outputs within REW I need this jack to be an output. So....can anyone recommend a USB mic and is it even recommended? -Rob | ||||
| | #2 | |||||
| Re: recommended USB microphone for REW Quote:
brucek | |||||
| | #5 | |||||
http://www.mxlmics.com/products/USB/...e_Classic.html I also checked its frequency response which was OK for acoustic measurements (+-0.5dB 30 to 15kHz, if I remember) | |||||
| | #7 | ||||
| Re: recommended USB microphone for REW You can use a USB mic, but the same caveats apply as when using a laptop or desktop mic input: the frequency response may be optimised for voice use (and so roll off at LF and perhaps at HF also) and the signal/noise performance may be poor. Without something to compare the results against it is hard to know whether a mic input is useful or not, though on a USB mic the frequency response (or at least its extents) should be in the spec somewhere. | ||||
| | #8 | ||||||
| | #9 | |||||
brucek | |||||
| | #10 | ||||
| Re: recommended USB microphone for REW "So the measurement quality depends only on the mic you use." It's probably been told before but Why can't i use, for example, an AKG perception 100, a MXL 2001 or overhead mics with the REW software instead of those pencil shaped measuring mic? Aren't these flat enough? What's the difference? | ||||
| | #11 | |||||
brucek | |||||
| | #12 | |||||
| | #13 | ||||
| Re: recommended USB microphone for REW The main difference between a measurement mic and a studio mic is usually the polar response. Measurement mics are omnidirectional, which allows them to capture the whole soundfield and makes them (fairly) insensitive to orientation. Studio mics are typically directional to varying degrees (cardiod, commonly) which means measurements taken with them will be very sensitive to the direction the mic is pointed and the contributions of the room coming from other directions will be atttenuated. | ||||
| | #14 | ||||
| Re: recommended USB microphone for REW Wouldnt you want a microphone that emilates a persons ears? They have these dummy heads that have testing microhpnes in them for headphone testing i would think somthign similar to this would be ideal/ Even if its just 2 microphones in mono. | ||||
| | #15 | ||||
| Re: recommended USB microphone for REW I think with REW and general room acoustics you are looking to measure how the sound is behaving in the room and not how you perceive it with your ears. You could then make mathematical assumptions geared towards how it would be heard. It would be much harder, if not impossible, to do it the other way around with a directional mic. | ||||
| | #16 | |||||
Somthing like that might be better for the full range speakers? *shrugs* | |||||
| | #17 | |||||
It sounds like you're wandering (unintentionally) towards the old loudness switches, that tried to contour the FR to mimic the the equal loudness curves... not necessarily a bad goal, but not exactly easy to implement... | |||||
| Bookmarks |
| Tags |
| microphone, recommended |
| Thread Tools | |
