| REW Forum How to best use REW to balance driversDiscuss How to best use REW to balance drivers in the Equalization | Calibration forum; How to best use REW to balance drivers laser188139 wrote:
Neat, Rudy.
I am by no means an expert. Most of the advice I've seen on the internet ... |
Views: 352 - Replies: 33
| | #26 | |||||
| Re: How to best use REW to balance drivers Quote:
Yes, this was all with Audyssey bypassed. The plots with Audyssey on are amazingly flat! That was what convinced me that Audyssey does what it says it does. I don't even have the professional version of Audyssey, just 8 measurement points and it does a great job for the sweet spot. Parasound HALO A52, A23 amplification, Integra DHC 9.9 Pre/Pro, Panasonic BD-55 Blu Ray. Mains - Khorns W/ALK crossovers, Eminence APT-150 tweeters, JBL 2470 on Trachorn. Center - La Scala W/ALK, Trachorn, & APT-150, Side Effects - 4 Cornwalls, Sub - SVS 20-39 PC+ 7.1 setup, Projector - Sharp Z12000, Dalite HP screen. HTPC for lossles .flac audio. My gear at: http://www.prontoweb.com/klipsch_HT.htm | |||||
| | #27 | ||||
| Re: How to best use REW to balance drivers Rudy, for anyone to play with your mdat file (other than to look at it as is), you need to provide the soundcard and meter calibration files that you're using. This is because the impulse response measure is taken without the influence of those files, so any gate manipulation would have to reapply the cal files to the frequency response, and so they would require them. brucek | ||||
| | #28 | ||||
| Re: How to best use REW to balance drivers brucek: Thank you. I appreciate all your comments, they help me learn about the software and about acoustic measurement. The attached files are the Asus board sound card and the ECM mic. Parasound HALO A52, A23 amplification, Integra DHC 9.9 Pre/Pro, Panasonic BD-55 Blu Ray. Mains - Khorns W/ALK crossovers, Eminence APT-150 tweeters, JBL 2470 on Trachorn. Center - La Scala W/ALK, Trachorn, & APT-150, Side Effects - 4 Cornwalls, Sub - SVS 20-39 PC+ 7.1 setup, Projector - Sharp Z12000, Dalite HP screen. HTPC for lossles .flac audio. My gear at: http://www.prontoweb.com/klipsch_HT.htm | ||||
| | #29 | ||||
| Re: How to best use REW to balance drivers Missed one. Looks like I can't upload the soundcard file here, so I will upload it to the web site mentioned before. Many, many thanks. Parasound HALO A52, A23 amplification, Integra DHC 9.9 Pre/Pro, Panasonic BD-55 Blu Ray. Mains - Khorns W/ALK crossovers, Eminence APT-150 tweeters, JBL 2470 on Trachorn. Center - La Scala W/ALK, Trachorn, & APT-150, Side Effects - 4 Cornwalls, Sub - SVS 20-39 PC+ 7.1 setup, Projector - Sharp Z12000, Dalite HP screen. HTPC for lossles .flac audio. My gear at: http://www.prontoweb.com/klipsch_HT.htm | ||||
| | #30 | |||||
The response called FR rev polarity shows a cancellation that would indicate the woofer and JBL are out of phase at the crossover. If two signals are in phase as they cross (just like a subwoofer and mains at the crossover), the resulting signal should be about 6dB higher. If I look at your mdat and do some gating, and show them with an expanded axis at the crossover of the woofer and mid JBL driver, I would say the response that you call Full Range (green trace in the first jpg below) could be considered a classic 6dB mix, and the correct polarity. The second jpg shows a dip around the crossover (blue trace) and I would consider it the incorrect wiring of the driver. Correct crossover ![]() Incorrect crossover ![]() brucek | |||||
| | #31 | ||||
| Re: How to best use REW to balance drivers brucek: I can't thank you enough for taking time to look at my plots. After looking at the plots myself, although nowhere near as closely as you could, I decided the 'standard' wiring matched the woofer best for the reasons you mentioned. I have already changed the wiring to 'standard' + to + and - to -. I will play with the plots so I can reproduce what you have done. This awesome program, REW, is still on a rather steep learning curve for me. Many thanks again! Parasound HALO A52, A23 amplification, Integra DHC 9.9 Pre/Pro, Panasonic BD-55 Blu Ray. Mains - Khorns W/ALK crossovers, Eminence APT-150 tweeters, JBL 2470 on Trachorn. Center - La Scala W/ALK, Trachorn, & APT-150, Side Effects - 4 Cornwalls, Sub - SVS 20-39 PC+ 7.1 setup, Projector - Sharp Z12000, Dalite HP screen. HTPC for lossles .flac audio. My gear at: http://www.prontoweb.com/klipsch_HT.htm | ||||
| | #32 | ||||
| Re: How to best use REW to balance drivers I'd love to learn more about this without harassing Bruce... could you post a link to the thread(s) you found? I've already gone through the help files again (which helped) but I feel I need more... | ||||
| | #33 | ||||
| Re: How to best use REW to balance drivers I ran a search in the REW forum for gating and one that had what I needed was this one: http://www.hometheatershack.com/foru...surements.html I have yet to really get into it, but plan on doing so in the next few days. I had to go back and start from scratch since brucek was good enough to PM me on some issues with my set up that could be done better. He has been a great help and his expertise is greatly appreciated. Parasound HALO A52, A23 amplification, Integra DHC 9.9 Pre/Pro, Panasonic BD-55 Blu Ray. Mains - Khorns W/ALK crossovers, Eminence APT-150 tweeters, JBL 2470 on Trachorn. Center - La Scala W/ALK, Trachorn, & APT-150, Side Effects - 4 Cornwalls, Sub - SVS 20-39 PC+ 7.1 setup, Projector - Sharp Z12000, Dalite HP screen. HTPC for lossles .flac audio. My gear at: http://www.prontoweb.com/klipsch_HT.htm | ||||
| | #34 | ||||
| Re: How to best use REW to balance drivers Thanks... Now I gotta make time for more reading/playing! ![]() | ||||
