High Low frequencies - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss High Low frequencies in the Subwoofer Equalization | Calibration forum; High Low frequencies I did my first measurement and set up of filters with my BFD. My crossover is set at 80 but ...
Old 10-29-06, 09:25 AM   #1 (Link)
Alias: tbrooke
User: #2212
Since: Aug 2006
tbrooke is offline
I did my first measurement and set up of filters with my BFD. My crossover is set at 80 but I noticed that several of the filters are set in the 100s. If my crossover is set at 80 are these filters doing anything. I noticed that my worst peak was at 110 so I need to do something up there. I don't understand crossovers so is some of the higher frequency info going to the sub or do I need to run my main spekers through the BFD (which I don't want to do)
Tbrooke
Old 10-29-06, 09:48 AM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: High Low frequencies
Crossovers aren't brick walls. They are a smooth transition for both the sub and mains. This can be seen by observing the target on the REW screen.
The higher you go above the crossover with respect to BFD filters, the less effective they become in controlling the outcome (once the mains are turned on).
This is why we first equalize with the sub only and try and get a response close to the target. Then when that's complete, we turn on the mains and do another response check and see the effect the combined sub plus mains have around the crossover. At this point you can adjust the subs phase control to get the best response. Then you can attempt some tweaking of those filters around and above the crossover to get an even better transition.
But as you've figured out already. A filter at 100Hz will have far less effect on this final process as a filter at 80Hz will....
Similar Threads
Low budget, high WAF IB, in-wall system report lcaillo DIY Subwoofers - Infinite Baffle 11 10-25-06 01:53 PM
My low budget gear :-) Exocer Home Theater Equipment 8 10-10-06 06:58 PM
which frequencies? dimmie REW Forum 145 09-29-06 05:26 PM
HDNet @ CEDIA - Filming high-def in high-def HDBeat HD Programming 0 09-16-06 04:06 AM
How Low Will Lucasfilm THX Go? Wayde Home Theater, Audio and Video News 4 06-27-06 10:23 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
