| REW Forum "Highest level in the measurement is -49 dBFS" need help with REWDiscuss "Highest level in the measurement is -49 dBFS" need help with REW in the Subwoofer Equalization | Calibration forum; "Highest level in the measurement is -49 dBFS" need help with REW So I'm using a SB Live external soundcard and I don't see any "right/left outputs" as John refers to in ... |
| | #1 (Link) | |||
| "Highest level in the measurement is -49 dBFS" need help with REW So I'm using a SB Live external soundcard and I don't see any "right/left outputs" as John refers to in the Help files and in other threads. These are the jacks it has: Mic In Phones C/Sub Rear Front SPDIF Out Line In (which I use for the SPL meter) So not sure which to connect to receiver from. So I tried all of them and I get that prompt (in title of this thread) when I am using Automatic Measurement. I turned my receiver up to -8 (which is crazy) and the prompt came again telling me to turn up my receiver. I'm doing something wrong in the SB-to-receiver setup and would like advice from anyone here that has been through this. I posted this on AVS too. Thanks | |||
| | #2 (Link) | |||
| Re: "Highest level in the measurement is -49 dBFS" need help with REW The "FRONT" will be the stereo left and right mains line-out jack. To ensure the sound card works, plug it into your receivers AUX plug and see if it passes sound (music mp3's etc) from your computer. Then test it with REW. brucek | |||
| | #3 (Link) | |||
| Re: "Highest level in the measurement is -49 dBFS" need help with REW "Front" does not send a signal to receiver. I tested with iTunes (and REW). The only jacks that send a signal to the receiver are optical, SPDIF (which is digital coax), and phones. But phones don't generate enough volume for REW. This is very frustrating and annoying. I thought Soundblaster Live external was supposed to work with REW. | |||
| | #4 (Link) | ||||
| Re: "Highest level in the measurement is -49 dBFS" need help with REW Quote:
I'm sure there's a method of forcing the default output to be analog. Perhaps someone else here uses this soundcard and can comment how to enable analog out? | ||||
| | #5 (Link) | |||
| Re: "Highest level in the measurement is -49 dBFS" need help with REW Ok "front" works via analog but signal is so weak. With digital, I get 80 db with receiver at -22. With analog, I get 54 db with receiver at -22. This is gonna be a problem if I try to do REW, right? Everything in soundcard control is maxed for volume. | |||
