| REW Forum The dreaded "little endian not supported" errorDiscuss The dreaded "little endian not supported" error in the Equalization | Calibration forum; The dreaded "little endian not supported" error Hi folks,
I downloaded REW last week and haven't yet had any luck getting it to work. Searching this forum ... |
Views: 988 - Replies: 5
| The dreaded "little endian not supported" error Hi folks, I downloaded REW last week and haven't yet had any luck getting it to work. Searching this forum shows a few other people with the same issue, but fixes seem to be a bit vague. It starts up fine, but when I try to select the input device, it always pops up the error: "line with format PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian not supported." I've tried every option in the soundcard control panel, but no success. The output device selection is the same except that the java sound engine does work; none of the others do though. (All the devices in the drop down menus have the word "emulated" in brackets after them - is this normal?) Soundcard is an M audio Audiophile 2496 (PCI version); it's in a DAW in my studio and has worked faultlessly with every other audio software I've used. It supports every sample rate & bit depth that REW can use. I've attached the soundcard debug file & main log file. Any help would be much appreciated Thanks, Shez | ||||
| | #2 | ||||
| Re: The dreaded "little endian not supported" error Hopefully you have selected output Audio Quality to 48kHz, 16 bits and ensure you select 48kHz as the sample rate in REW. Have you tried selecting a wave control name since the default doesn't seem to work in the soundcard pulldown.. ![]() Have you tried using the soundcards own mixer (rather than the windows mixer which REW controls) and set the LINE_IN volume and LINE_OUT volume... brucek | ||||
| | #3 | ||||
| Re: The dreaded "little endian not supported" error Hi Brucek, I've set the soundcard to 48k, but it doesn't offer any choice on bit depth; it's a 24 bit card. The soundcard drop down menu you pictured doesn't behave like that for me - none of the sub menus actually display, I just get a little grey square dot to the above right of the black triangle. I'm not sure that the soundcard's mixer is relevant yet as REW doesn't seem to get as far as being able to see any input. The faders are all up in any case. Thanks for replying, Shez | ||||
| | #4 | |||||
| Re: The dreaded "little endian not supported" error Quote:
brucek | |||||
| | #5 | ||||
| Re: The dreaded "little endian not supported" error I'll have another play tonight (I'm away from the studio at the minute) but if memory serves, pressing the red button just results in the error popping up - I don't think I can get as far as REW acknowledging that there is an input available, regardless of what level it might be at. The meters on the soundcard's mixer show a healthy input. Shez ![]() | ||||
