REW Forum
Just getting started
Discuss Just getting started in the Equalization | Calibration forum; Just getting started I have not purchased anything yet,but plan to buy a BFD. I have a G3 Mac running X and downloaded ...
Views: 596 - Replies: 3
Old 11-02-06, 09:35 AM   #1
Alias: ryan
Loc: louisville KY
User: #3190
Since: Oct 2006
  rosco968 is offline
I have not purchased anything yet,but plan to buy a BFD. I have a G3 Mac running X and downloaded REW. I am considering the Behringer ECM800 mic and a UB502 mixer with phantom power for the mic.
How is this used instead of a Shack SPL meter?
Are there any printable instructions for the REW software?
I need help!!!
TIA
Ryan
Old 11-02-06, 10:05 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Just getting started
It's used the same as the RS meter, except the ECM8000 doesn't have a meter on it to indicate the actual SPL level in the room. At one point in the setup for REW, you use a RS meter held near the ECM8000 mic to establish the level in the room. No big deal.
REW Help files
Old 11-02-06, 02:37 PM   #3
Alias: ryan
Loc: louisville KY
User: #3190
Since: Oct 2006
  rosco968 is offline
I thought I could get away with not buying the Shack SPL meter, but if I need one with the good mic to set it up, I guess I won't get the good mic.
Thanks,
Ryan
Old 11-02-06, 04:06 PM   #4
Alias: brucek
User: #6
The good mic is quite inexpensive and quite accurate.
