| REW Forum Target response / House curveDiscuss Target response / House curve in the Equalization | Calibration forum; Target response / House curve What is the difference between the Target response and the House curve ?... |
Views: 1303 - Replies: 6
| | #2 | ||||
| Re: Target response / House curve Target response is either with or without the house curve. House curve is just compensating for how bass sounds in your ears in your house. Normally a house curve raises the level from 80Hz(0dB gain) to 30 Hz(5-8dB gain). House curve is added, together with other calibrations like soundcard and mic. To calculate the response you want/need in your room (Target response). | ||||
| | #3 | |||||
| Re: Target response / House curve Quote:
| | #5 | |||||
Speaker Type should be set to subwoofer in this application. Bass management includes Low Pass Filtering of the subwoofer signal. We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||||
| | #6 | ||||
| Re: Target response / House curve Like this Target Level = 75 dB ![]() Target Level + Low Pass Filter (Subwoofer Cutoff) @ 80 Hz ![]() This House Curve adds an 8 dB rise from 80 Hz down to 30 Hz. ![]() Target Level + Low Pass Filter + House Curve = Target Response ![]() Filter your measured response to hit the target. ![]() We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | ||||
