Error in Help ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Error in Help ?
Discuss Error in Help ? in the Subwoofer Equalization | Calibration forum; Error in Help ? In Help , page Filter Adjustment : The optimiser limits its range of Q/bandwidth adjustment so that filters do not ...
Old 11-07-06, 08:17 AM   #1 (Link)
Alias: sonata31
Loc: France - Toulouse
User: #875
Since: Jun 2006
sonata31 is offline
Error in Help ?
The optimiser limits its range of Q/bandwidth adjustment so that filters do not get narrower than 3Hz bandwidth or broader than 15Hz and Q does not get lower than 3.0. This is because it is targeting room resonances, which occupy that range of bandwidths. For broader or narrower filters make manual adjustments.
15Hz ??
Old 11-07-06, 08:50 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Error in Help ?
15Hz ??
This is filter width....
Old 11-07-06, 11:40 AM   #3 (Link)
Alias: sonata31
User: #875
Since: Jun 2006
sonata31 is offline
Re: Error in Help ?
brucek wrote: View Post
Yes I Know
Why 15Hz ? It is not much !
Old 11-07-06, 01:00 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Error in Help ?
I don't think so. That's the filter bandwidth at the half gain points.
Certainly as you go lower in frequency, it makes for a larger filter. This is simply the maximum that REW calculates. You can go wider manually though.
Here's a ~15Hz filter width at 30Hz and at 100Hz.
Old 11-07-06, 06:27 PM   #5 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Re: Error in Help ?
sonata31 wrote: View Post
Yes I Know
Because modal resonances are narrower than that.
Old 11-08-06, 03:43 AM   #6 (Link)
Alias: sonata31
User: #875
Since: Jun 2006
sonata31 is offline
Re: Error in Help ?
Ok, Thank You for your responses
Similar Threads
REW win98 error mike c REW Forum 7 01-18-07 10:16 AM
The dreaded "little endian not supported" error Shez REW Forum 5 11-01-06 03:20 AM
New Soundcard drivers gives REW an error. Exocer REW Forum 8 06-18-06 02:20 PM
Computer Error Sonnie Chat Box 1 06-14-06 12:11 PM
Mach 5 Audio
