| REW Forum My first measureDiscuss My first measure in the Equalization | Calibration forum; My first measure I made my first measure of my sub :
When I click on Find Peak I get the message :
Views: 1174 - Replies: 48
| My first measure I made my first measure of my sub : ![]() When I click on Find Peak I get the message : Largest peak found was 29,6dB Target Level may bet set incorrectly (too low) Yet the Target Level = 80.5dB ?? | ||||
| | #2 | ||||
| Re: My first mesure have a look at the frequency range under the find peaks button. You may have the upper figure too high, eg at ( say) 100 hz you may have a signal at 100 db, but the target curve at that frequency may be at 60 hz, giving you a peak of 40 hz. In all likelihood the upper figure will be something like 200 hz, try setting it to 100 hz or a more appropriate figure, lots of love terry | ||||
| | #4 | |||||
| Re: My first mesure Quote:
The results of Find Peak depend of the Cutoff parameter ? What value for Cutoff with this response ? | |||||
| | #5 | ||||||
You are showing a target cutoff for filter suggestion at 60Hz. Is that the crossover setting on your system, because it looks more like 80Hz as shown in the overlay below where I added a 80Hz line... Quote:
![]() brucek | ||||||
| | #6 | ||||
| Re: My first mesure My connections are : Ampli Yam (used like pre-ampli) --> DCX2496 --> DEQ2496 --> Ampli --> Front |------------------------|------------|--------------------> DEQ2496 --------------> Sub |------------------------|---------------------------------> DEQ2496 --> Ampli --> Centre |------------------------|---------------------------------> DEQ2496 --> Ampli --> Surrounds |--------------------------------------------------------------------------------> Surrounds back This for use my sub in Hi-Fi (mode stereo pure direct on the Yam) For the test the DCX is bypassed (no crossover), the DEQ is bypassed (no PEQ) and the ampli of front is turned off | ||||
| | #12 | |||||
If the mains speakers have a -3dB down response to 40Hz (for example), you would set the crossover at an octave above that. So they would have to be extremely capable speakers to choose a crossover below 80Hz. That's the preferred crossover. You'll obviously have less equalization control if anything less is chosen. Subwoofer crossovers are forced at the upper end, so generally set at a fourth order LP and so -24dB per octave would be suitable. For the mains which enjoy a natural falling off at the lower end, then a second order -12dB per octave would be correct. The cutoff in REW is always set to match the crossover frequency. brucek | |||||
| | #13 | ||||
| Re: My first mesure The subwoofer target response on REW is based on a 24dB/octave roll-off, per THX recommendations for bass management, which is why you see a better match between actual and target shapes with the DCX set to 24dB. | ||||
| | #18 | ||||||
| Re: My first measure Quote:
brucek | ||||||
| | #19 | |||||
| Re: My first measure Good French Quote:
![]() ![]() A filter PEQ with 7-8dB is correct ? | |||||
| | #20 | ||||||
brucek | ||||||
| | #21 | ||||||
| | #23 | |||||
Reduce the area from 40Hz to 80Hz a little bit and you're done..... brucek | |||||
| | #24 | ||||
| Re: My first measure I have already set filters to the DCX !!! | ||||
| | #25 | |||||
Dial down the filter gain in that area a few dB and remeasure... If you saved the unfiltered .mdat file and the filter .req file, then you can play with the filters manually in REW to see the effect... brucek | |||||
