REW Forum
Using REW filter info
Discuss Using REW filter info in the Equalization | Calibration forum; Using REW filter info Hi, 1st post so go easy !!. I have just acquired a BFD to incorporate into my system at home. ...
Views: 558 - Replies: 2
Old 11-13-06, 04:29 PM   #1
New Member
Alias: Mick
Loc: Adelaide
User: #2080
Since: Aug 2006
  mgrobins is offline
Hi,
I have just acquired a BFD to incorporate into my system at home. I've been using REW for some time without the BFD to measure and improve my setup via placement changes.
I only have a choice of com-port (serial D-Sub) output on my pc in the lounge (old dell micro pc) and was hoping someone can clarify 3 points for me.
1. Can I use a com port to communicate with the BFD midi? (i.e d-sub on one end and 4-pin din on the other??). What pin outs would I need? Are there any other choices I have for a midi connection? (In the system area of xp my sound hardware does not list a midi).
2. The filters in REW have gain and Q settings in fractions. I have to round them to enter them manually. Does use of the midi allow more control by setting fractions?
3. The "Q" setting in REW for each filter. When entering the values into the BFD do these transpose across directly (eg Q of 5 -> enter five for bandwidth on the BFD) or do I need to do some sort of conversion??
I have been entering and storing my filters but the Q value is a ?? to me as the filters have created a response different to what was anticipated.
PS: I have read the help files, manuals and many threads here...
cheers.
Old 11-13-06, 05:43 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Using REW filter info
You have the incorrect equalizer selected.
Select the BFD1124 as shown below and the filters are ready to enter directly into the BFD....
Old 11-13-06, 07:17 PM   #3
New Member
Alias: Mick
Loc: Adelaide
User: #2080
Since: Aug 2006
  mgrobins is offline
you're a champ thanks .
All under control now. Time to learn about house curves
