REW Forum
sweep or sine wave ?
Discuss sweep or sine wave ? in the Equalization | Calibration forum; sweep or sine wave ? Hey Folks What is the right way to measure ? Sweep or Sine wave ? Because I always thouhgt that ...
Views: 807 - Replies: 11
Old 11-20-06, 04:37 PM   #1
Bergowitz
Inactive
Alias:
User: #
Posts: n/a
Hey Folks
What is the right way to measure ? Sweep or Sine wave ? Because I always thouhgt that the right way was sine waves. But then yesterday I read the help file completly one more time, and saw that the suggested method was sweep. How coluld i not have seen that in the first place So I tried sweep, and that made a moo baby moo of a difference. + my room doesn´t seem to be that "acoustic good"
So what is the most right way ?
I´ll try to post some graphs soon. So u guys can help me
And 1 more thing. My soundcard doesn´t have line-in. But it has wave, mic, stereo mix, and one more thing I don´t remember right now. (It´s a labtop i borrow from someone, and i brought it back again)
Which one is the right one to use then ?
Old 11-20-06, 06:20 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: sweep or sine wave ?
Sweep..............
You need a line_in. This a standard problem with a laptop. Most people with a laptop must get an external sound card driven from the USB port.
Old 11-20-06, 11:40 PM   #3
Alias: BlueDude
User: #3165
Since: Oct 2006
  Blue Dude is offline
Would one of those cheapie $5 USB keychain sized sound cards be suitable for this use? My laptop has a similar input limitation and needs a workaround.
Old 11-21-06, 12:25 AM   #4
Bergowitz
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
Can you recommend an external soundcard ?
Old 11-21-06, 04:06 AM   #5
Alias: brucek
User: #6
  brucek is offline
Just about any soundcard that is full duplex and had line-in and line-out connections will work. Any inadequacies are compensated for in REW after you carry out a soundcard calibration (the first part of REW setup).
Several members here use the Soundblaster Live! 24-bit USB. It works fine with REW.
Old 11-22-06, 11:12 AM   #6
Bergowitz
Inactive
Alias:
User: #
Posts: n/a
I have ordred a Soundblaster Live 24 yesterday. So I´ll post some graph this weekend hopefully.
Old 11-22-06, 11:24 AM   #7
Alias: brucek
User: #6
  brucek is offline
Be sure to read this thread...............
Old 11-22-06, 11:55 AM   #8
Bergowitz
Inactive
Alias:
User: #
Posts: n/a
I´ll do that.
And I´ll need two y-split cables mini-jack (stereo) -> RCA for this soundcard setup right ?
1 from SPL -> soundcard
1 from soundcard -> A/V processor
Old 11-22-06, 12:07 PM   #9
Alias: brucek
User: #6
  brucek is offline
Not really a Y-split (which implies mono), but a (stereo mini-plug to two mono plugs) adapter.
The soundcard line-in and line-out jacks are both stereo and require a stereo plug (of which you'll only use the right channel).
Old 11-22-06, 04:20 PM   #10
Bergowitz
Inactive
Alias:
User: #
Posts: n/a
My bad. That was actually also what I ment. But I just named them wrong.
So 2 of thoose will do ? Also just the right one to my A/V processor ? Does that make a different ?
I´m getting my soundcard tomorrow. So I´ll be tweakin´ the whole weekend
Is it not good to use the sub to tame a peak ? Because I think I have a large one at around 50 hz
Sorry for all the questions. But I would like to make it right this time
Old 11-22-06, 04:45 PM   #11
Alias: brucek
User: #6
  brucek is offline
Yep, two of those will do.
Yeah, you send the right channel from the soundcard to the A/V processor, but many people at that point split the signal (with a splitter) to feed both the right and left CD or AUX input, so when you add the mains after equalizing the sub, you get a right and left channel mains to check the interaction at the crossover...
Use REW with the sub only to setup the BFD filters. Then, when finished, add the mains and do a response to check the interaction at the crossover for any further tweaking...
Old 11-23-06, 10:09 AM   #12
JBL-4645
Inactive
Alias:
User: #
Posts: n/a
Performing a sine wave sweep is a tricky matter, you have to remain very still and quite as the wave or tone will be disturbed by any movement as the sound bounces off of you!
It’s better to be on the outside and while the tone goes though from 20Hz to 20KHz you can later analyzer the data on the pc.
All the fronts should have the same tone at the same spot, but often this needs addressing by an equalizer, the manual touch makes it more personal, you’re setting it to what is written down on paper you setting it for a flat response at the sweet spot and that’s all that can be done it’s not possible to have it the same throughout the whole room, and that would be very ideal but it’s not possible.
Once done check it out with some music and some film material to see what else is left, often a few more tweaks here and there across the fronts. You’ve got to have the right amount to cater for the ear not to bright and not too boomy, that’s mostly down to the reproduction of the CD or the films soundtrack.
To compensate for are own hearing loss at different frequencies is pointless, as friend might point out, “it’s too bright what on earth have you done here?” And being too bright will result in failure of the HF on one or more of the fronts if the films soundtrack level goes why too high, and with the boosted high frequency on your home cinema set-up, well you can say good bye to the HF!
