Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss REW is spitting through my system in the Equalization | Calibration forum; REW is spitting through my system OK, well that's what it sounds like ... spitting. I installed the latest REW on my Win 7 32-bit laptop, ...
Views: 195 - Replies: 11
Old 02-08-10, 10:32 AM   #1
Alias: pepar
pepar's Avatar
Loc: On an island
User: #837
  pepar is offline
I installed the latest REW on my Win 7 32-bit laptop, connected my M-Audio MobilePre and installed the latest drivers, selected it as the default device(s) and launched REW. I was able to measure and generate a cal file for the "soundcard," but when I went to measure and set levels I got "spitting" along with the noise. And I got that spitting with both Use Main Speaker and Use Subwoofer. (I was connected to the Aux2 front panel Left analog input with mode set to mono using bass management.)
My system sounded normal for the Superbowl game, and I did play a few WAVs from the laptop through my system that sounded normal as well. I guess I will re-check my connections and play some music through the MobilePre to my system.
Does anybody have any other ideas? Remove and reinstall REW???
Jeff
Old 02-08-10, 01:41 PM   #2
Shack Moderator
Alias: Greg
glaufman's Avatar
Loc: NY
User: #13758
Since: Nov 2007
  glaufman is offline
Re: REW is spitting through my system
Hmmm... spitting?
Post a pic of your soundcard cal file. Before "setting" levels did you try "check levels?"
Any messages?
-Greg
Don't worry... nothing new here, I've already made that mistake. Trust me.
Old 02-08-10, 01:56 PM   #3
Alias: pepar
pepar's Avatar
Loc: On an island
User: #837
  pepar is offline
glaufman wrote: View Post
Hmmm... spitting?
Any messages?
No messages were displayed.
Basically, I stepped through the setup in 'order of appearance" - Calibrating the Soundcard and then Checking Levels. Whether the higher pitched noise from using the Main speaker or the lower frequency noise from using the subwoofer to check levels, the spurious noise is present. I'm pretty sure that nothing was clipping.
I will post the soundcard cal tonight, and maybe even capture and post a WAV file of what I am hearing.
Thanks,
Jeff
Old 02-08-10, 02:37 PM   #4
Shack Moderator
Alias: Dan
Moonfly's Avatar
Loc: Lancashire - UK
User: #23785
Since: Aug 2008
  Moonfly is offline
A wav file or video of the problem will probably be a big help. Ive never come across this one before and its difficult to relate to the issue.
Onkyo 875 + CA Azur 640A | AV15-X Dual Push/Pull DIY Sub | Bose 203 Fronts | MA R250 Center | MA R270 Rears
Is there a cure for this addiction
Click Here for the new Gaming Forums
Old 02-08-10, 03:40 PM   #5
Shack Moderator
Alias: Greg
glaufman's Avatar
Loc: NY
User: #13758
Since: Nov 2007
  glaufman is offline
Well, the first thing will be to make sure the soundcard calibrated correctly. I assume when calibrating it you went through setting the input level appropriately.
-Greg
Old 02-08-10, 03:44 PM   #6
Alias: pepar
pepar's Avatar
Loc: On an island
User: #837
  pepar is offline
Did that. The soundcard measurement step went as smooth as it always has. But I will start from scratch again tonight after re-checking all of my cabling/connections.
Jeff
Old 02-08-10, 07:23 PM   #7
Shack Moderator
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Something with the Sample Rate maybe, or the Replay/Record Buffers?
Old 02-08-10, 09:10 PM   #8
Alias: pepar
pepar's Avatar
Loc: On an island
User: #837
  pepar is offline
After a lot of double-checking connections - and changing from 48KHz to 44.1KHz on both soundcard and REW, I finally got a soundcard cal result that looked normal and was able to proceed to taking a measurement.
I don't understand the sampling rate thing because the soundcard and REW were both on the same page, but that seemed to be the change that made the difference.
Jeff
Old 02-08-10, 09:14 PM   #9
Shack Moderator
Alias: Greg
glaufman's Avatar
Loc: NY
User: #13758
Since: Nov 2007
  glaufman is offline
Glad it's working out!
-Greg
Old 02-08-10, 09:21 PM   #10
New Member
Alias: Scott
Loc: Wisconsin, USA
User: #45512
Since: Nov 2009
  SRW1000 is offline
Here's one more thing to try: Unplug your laptop.
I was getting an awful lot of spitting/hissing/crackling noise when I first set up REW, and I didn't know what the problem might be. After buying a new sound card, and still getting the problem, I unplugged the power cord and ran off the battery only. The extra noise was instantly gone.
Since then, I always run REW off the battery.
Scott
spitting, system
Bookmark and Share
Dish Network
