REW Forum
USB to MIDI interface...
Discuss USB to MIDI interface... in the Equalization | Calibration forum; USB to MIDI interface... I am using a Toshiba tablet PC for REW. I was able to calibrate it just fine, and everything seems ...
Views: 1204 - Replies: 3
Old 11-28-06, 10:19 AM   #1
Alias: Paul
Loc: SW Ranches, Fl
User: #3355
Since: Oct 2006
  aceinc is offline
I am using a Toshiba tablet PC for REW. I was able to calibrate it just fine, and everything seems to work but I am getting tired of manually setting the BFD.
I have seen a couple of USB to MIDI cable/boxes, but do not know which, if any, will work with REW & BFD. Does anyone have any experience with any USB to MIDI converters and REW? If so which is the least expensive device that works?
Paul
Old 11-28-06, 10:26 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: USB to MIDI interface...
You should read this thread before you waste time on something that doesn't work.
Old 03-03-07, 08:19 PM   #3
bcrawfo2
Inactive
Alias:
User: #
Posts: n/a
I confirmed I'm running v1.0 of the firmware. What is a popular budget USB-MIDI interface?
I found this -> http://www.sweetwater.com/store/detail/XMIDI1x1/ for $30 with free shipping. Any experience with this?
I know how to program with the front panel, but it sure is a PAIN.
Thanks
Scott
Old 03-03-07, 09:59 PM   #4
Alias: Mike
Loc: Montreal
User: #5316
Since: Jan 2007
  pinduro is offline
Hi Scott,
Check out the web for the craigslist in your area...if its anything like the one in mine, you might find a midi i/o for cheap.
good luck
Mike
