| REW Forum REW: Export Filters Response as wavDiscuss REW: Export Filters Response as wav in the Equalization | Calibration forum; REW: Export Filters Response as wav I would like to make an impulse response to use in convolver for foobar2000. (to EQ my headphones) I think ... |
Views: 900 - Replies: 3
| REW: Export Filters Response as wav I would like to make an impulse response to use in convolver for foobar2000. (to EQ my headphones) I think that REW can make one, but I can't figure out how to do it. I have set up three filters, and I have tried to use the feature in the file/export menu, but it doesn't seem to make the file. Can you help? We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | ||||
| | #2 | ||||
| Re: REW: Export Filters Response as wav Nevermind, I figured it out. First you have to import a pulse. I made one with a trial version of Test Tone Generator. I sucessfully set filters and exported an impulse response. I referenced that response with convolver in foobar2000 and... I now have paramtric EQ for my headphones. REW rocks the house!(I have tried to figure out how to use convolver off and on for a year, and I finally got it.) ![]() To set the filters I used swept sines as suggested by Mr. Linkwitz. My ears are now tired of listening to HF sweeps. We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | ||||
| | #3 | ||||
| Re: REW: Export Filters Response as wav I just tried it with V3.29 and it worked fine for me. But when I tried it with V3.30Beta (which I presume you're using), it doesn't work. It appears it only creates a file when there is something in the impulse plot. If I only enter filters, it doesn't work. Revert back to V3.29 and try it. brucek | ||||
| | #4 | ||||
| Re: REW: Export Filters Response as wav I've fixed that, thanks | ||||
