REW Forum
Crashing A Lot (Mac OS X)
Discuss Crashing A Lot (Mac OS X) in the Equalization | Calibration forum; Crashing A Lot (Mac OS X) I downloaded the latest Room EQ Wizard and tried running it on my Dual 2GHz G5 PowerMac. I'm running Mac ...
Views: 830 - Replies: 2
Old 12-03-06, 03:53 PM   #1
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
I downloaded the latest Room EQ Wizard and tried running it on my Dual 2GHz G5 PowerMac. I'm running Mac OS 10.4.8 with the latest patches, and using J2SE 5.0. With this, I was getting Room EQ Wizard crashes about every 5 minutes. Almost impossible to use. Seemed to happen more often when I included sweeps and measurements <20Hz, but the crashes would not always happen while I was actually taking measurements. Also sometimes while playing with filters. And it happened at least once when I hadn't taken any measurements below 10Hz.
I looked at a bunch of the crash logs. They're all bus errors at PC=0x9c4fbe80. I've attached one of the logs. It kind of looks like a JVM error though. But seems it shouldn't be happening so often; there must be tons of Mac apps using this code in Java.
Old 12-04-06, 04:10 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Crashing A Lot (Mac OS X)
Hi Josuah,
These are JVM crashes, unfortunately. I have taken the plunge however and bought a Mac Mini to see if I can find out what is upsetting Apple's JVM and work around it.
Old 12-04-06, 10:24 PM   #3
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
Cool. If you need help, let me know. I'm a software developer and have worked some on Apple's CoreAudio side a while back.
