need some help calibrating - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss need some help calibrating in the Subwoofer Equalization | Calibration forum; need some help calibrating I'm not gonna mess with this tonight. Hockey game... and had a real bad morning @ work, so i wasnt ...
Old 12-04-06, 07:27 PM   #26 (Link)
Alias: Mo
User: #4519
Since: Nov 2006
CSEmoses is offline
Re: need some help calibrating
I'm not gonna mess with this tonight. Hockey game... and had a real bad morning @ work, so i wasnt in a great mood when i started this, this afternoon. Then i had trouble with it... man, i was just about ready to throw the RS SPL meter out a window... not that I ever would.
Would it be easier to 'walk' me through this over the phone? I only ask because i've got unlimited long distance in North America.
Old 12-04-06, 07:29 PM   #27 (Link)
Alias: Mo
User: #4519
Since: Nov 2006
CSEmoses is offline
One more thing. In my mixer control panel thingy, which looks like yers, Line In is under playback, not recording. Strange....
anyhow, i'll give it another shot sometime tomorrow, maybe in the early evening.
Old 12-04-06, 07:44 PM   #28 (Link)
Alias: brucek
User: #6
brucek is offline
That's normal. I think it's actually listed under both in mine.
Once you've played around with this for a bit, you'll find it easy...
Old 12-05-06, 06:38 PM   #29 (Link)
Alias: Mo
User: #4519
Since: Nov 2006
CSEmoses is offline
BruceK, i'm having trouble understanding what i need to do while setting the 'Input Volume'. It gives me the message shown in the following linked picture:
http://www.imagemonster.net/is.php?i...error_when.jpg
What am i supposed to do here?
my receiver is at my normal listening volume for LOTR type movies, which is where I want it for the tests, and happens to be where it reads the targeted 75db in the first Set Measurement Level calibration.
Am I correct in saying that if i increase my system volume, the Set Measurement Level test is for naught, because the Input Volume calibration is based on the setting (on the RS meter) used in the Set Measurement test?
Old 12-05-06, 06:44 PM   #30 (Link)
Alias: Mo
User: #4519
Since: Nov 2006
CSEmoses is offline
I totally made a bad assumption!
When doing the original Set Measurement Level, i was reading the amount shown in the big black letters at the left of the REQW screen, assuming that this was a straight reading from the RS meter... which it obviously wasnt.
Now then! ... i went and looked at the SPL meter, and did both the set measurement level, and set input volume tests correctly (i hope!) and i'll move onto the next ones here shortly.
Will update if need be
thanks again, man!
Old 12-05-06, 07:00 PM   #31 (Link)
Alias: Mo
User: #4519
Since: Nov 2006
CSEmoses is offline
Ok, i'm onto the soundcard calibration... the explanation built into REQW isnt exactly clear... see image:
http://www.imagemonster.net/is.php?i...soundcard_.jpg
Am i supposed to match the number in the 'Soundcard Measurement Inp' window with the big black 7.3 on the left side there?
Think i'm almost ready to (accurately) measure my little subwoofer! *cheer*
Old 12-05-06, 07:19 PM   #32 (Link)
Alias: brucek
User: #6
brucek is offline
No, you don't do anything here other than hit CONTINUE and REW takes care of doing the test.
BTW, have you read the very excellent REW HELP FILES? They explain all this very simply.
Old 12-05-06, 08:14 PM   #33 (Link)
Alias: Mo
User: #4519
Since: Nov 2006
CSEmoses is offline
OK bruce, we're measuring!
only one questions for you though no error message this time... heh...
Why do you say to measure to 200hz? isn't there a crossover in the AV processor, even with the mains set to small, that's going to throw all the stuff over say 120hz to the mains?
Anyhow, i'll post a graph measuring from 25hz to 134hz, as above that there's no point.
http://www.imagemonster.net/is.php?i..._correctly.jpg
The **** <img> tags arent working.
Old 12-05-06, 09:43 PM   #34 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Here it is:
Old 12-05-06, 10:14 PM   #35 (Link)
Alias: brucek
User: #6
brucek is offline
Measure from 10Hz to 200Hz. The automatic sweep starts at DC and then ends an octave above 200Hz. This ensures the response is accurately captured throughout the requested range.
Use horizontal axis from 15Hz to 200Hz and vertical axis from 45dB to 105dB.
Set your graph to LOG and not LIN.
Old 12-05-06, 10:51 PM   #36 (Link)
Alias: Mo
User: #4519
Since: Nov 2006
CSEmoses is offline
hrm, i thought i had the axis set correctly.
and i swear i thought i had it set to log
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
