REW Forum
need some help calibrating
Discuss need some help calibrating in the Equalization | Calibration forum; need some help calibrating OK. So when i laund REQW, it tells me it's loaded the RS SPL meter calibration file i donwloaded: fine. ...
Views: 1016 - Replies: 35
Old 12-03-06, 05:47 PM   #1
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
So i've connected the RS SPL meter to the line input, i've told it to record without monitoring.
So then i launch REQW, and try running calibration wizards.
1. I do the set input volume, which works fine, or so it seems.
2. I try the 'calibrate' button, and the readings on the SPL meter are @ around 100db... since the scrollable menu that i'm told to match to what my SPL meter shows only goes to 90db, I'm thinking something is wrong.
Should I simply turn down the master volume control on my computer? wouldn't that be screwing with the calibration?
I tried turning the system volume down to 1/2, but then the 'set input volume' wouldn't work.
So i turned the system volume up to about 3/4, and it did work. Then i used the calibrate button, and had to set it to 88db.
Something just doesn't seem or feel right here.
Any help would be appreciated.
Old 12-03-06, 06:22 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: need some help calibrating
Hopefully you're using stereo adapters on your line-in and line-out jacks of the soundcard, and only using one channel of those adapters (usually the right).
Ensure the sub is on and the rest of your speakers disconnected (or external power amps off if you have them).
Have the normal sub crossover set (80Hz for example).
Have your receiver in STEREO mode with speakers to small.
First you should SET MEASUREMENT LEVEL and adjust your receiver volume to 75dBSPL on the RS meter in your listening position. Now we know the room is at 75dBSPL. Output done.....
Next SET INPUT VOLUME. Input done.
Next CALIBRATE the REW SPL meter to the RS meter. Now both meters match.
The next one time event is to put a short between the line-in and line-out and Measure Soundcard Response to create soundcard calibration file and save it, so it loads every time hence.
Put your normal cables back on.
Now set the TARGET LEVEL.
Then AUTOMATIC MEASURE to 200hz. Use horizontal axis of 15Hz to 200Hz and vertical axis of 45dB to 105dB.
Old 12-03-06, 06:41 PM   #3
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
actually, for testing my sub, i was running the white RCA straight to the subwoofer, bypassing the receiver completely. I will follow your method next time.
Question about your terminology there:
what do you mean by a 'short' between the line-in and line-out on my sound card?
Old 12-03-06, 07:23 PM   #4
Alias: brucek
User: #6
  brucek is offline
A short cable with male 1/8" stereo plugs on either end. The soundcard has stereo jacks so you need a stereo cable. Only one channel will be used, but you still need the right connection to make it work.
This cable shorts (connects) line-out to line-in...
Or you can short the cable you are connecting to your receiver to the cable you're using for your meter with an adapter.
Old 12-03-06, 07:26 PM   #5
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
uhg, another cable to buy! ah well...
as is, i've got two 1/8" stereo to L/R RCA 'Y' cables, one in the Line In, and another in the same jack that i plug my headphones into, and an RCA running to my RS meter, and the other to the reciever or sub.
So, i just need to get a 1/8" stereo to 1/8" stereo cable now, eh?
Old 12-03-06, 07:37 PM   #6
Alias: brucek
User: #6
  brucek is offline
Yep, or simply use a female to female RCA adapter to make the short with the cables you have.
I can't imagine you haven't got the 1/8" cable. I don't know a piece of equipment I've purchased that didn't come with one that now sits in a drawer...
Old 12-03-06, 07:40 PM   #7
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
i purchased my receiver from a friend, in a horse-trade, heh ... didnt come with a 'short' cable... but yeah, I definately could use one of the female-femaile RCA couplers i've got to do that... sweet.
For the sake of simplicity, can I do all of this but with the speaker-out RCA going directly to my sub?
Old 12-03-06, 07:53 PM   #8
Alias: brucek
User: #6
  brucek is offline
Speaker out? Do you mean line-out? If so, I recommend highly that you feed the receiver (AUX or CD) input. Then you will engage the crossover. It will give a better idea about filtering or positioning if that's the purpose of the exercise.
You will also have the receivers volume control to set the level with.
You'll also get a better idea of how the mains integrate with the sub around the crossover once you get to that step of the process.
Old 12-03-06, 07:55 PM   #9
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
Sounds good.
I'll give it a try ASAP and post here with any other questions / concerns.
Old 12-04-06, 05:10 PM   #10
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
arhg.
Ok, i've got it all hooked up the way you suggested. I did the Set Measurement Level just fine... but when i go to set input level, it gives me the "input volume control is at it's maximum" message ' the wizard was not able to set the input signal RMS level to -18db, even with the volume control at it's maximum setting. If the signal is above -24db it will probably be OK and the correct input has been selected."
So, in order to 'set the input volume' i had to lower the RS SPL dial a notch, down to "70" ...
so onto the next step i go.
i hit the calibrate button, and it tells me to match the number in the box with the one shon on the RS meter readout (the one in big numbers at the left of the screen) ... which i cannot do! the meter readout shows 96db or thereabouts, so i had to go change the RS meter dial (again) back to 80db setting. Tried it again, and I was able to match the numbers.
Is this correct? *confused*
Old 12-04-06, 05:16 PM   #11
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
While i await your answers on the above, i've moved onto the Soundcard calibration ...
is the value in the up-down clicky box supposed to match the value displayed in the 'db SPL' box at the left? (where your RS meter is normally showing readins) ... to match, mine needs to be clicked up to -28, does that sound normal?
Thanks again!
Old 12-04-06, 05:39 PM   #12
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
OK, i think i'm going insance. I switched back to my 'normal' cable setup, and now I cant send anything from my computer to the receiver and hear it.
Old 12-04-06, 05:52 PM   #13
Alias: brucek
User: #6
  brucek is offline
When you see this, it means there is not enough level from the Radio Shack SPL meter feeding the line-in connector. See below.
Yes, correct. The meter should be dialed and left at 70 because you're going to be calibrating to 75dB...
I'm a little confused about that? You set the Measurement level so the the RS Meter shows 75dB and then you set the input level. So now you want to match that 75dB actual reading from the RS meter to the REW meter. So set the REW meter to 75dB.... Now the RS meter reads the same as the REW meter. Leave the RS meter at 70 on the dial for the entire exercise. Don't move it or your receiver master volume once set. If you do, simply start over....
Sorry, don't understand this. Once your levels are set and you attach the loopback cabel, pull down the Soundcard selection and execute the Soundcard measurement routine.
Old 12-04-06, 05:55 PM   #14
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
OK, starting again I guess. I'll post an update soon.
Old 12-04-06, 06:12 PM   #15
Alias: brucek
User: #6
  brucek is offline
Oops, just re-read my post and realized I better stop relying on my bad memory. I don't mean to say set the RS meter dial at 70, I do mean to say set it at 80 on the dial and set the calibration to 75dB in REW. This then gives you lots of headroom from 75dB so the RS meter needle won't peg when running measurements.
Sorry, for the mixup. I use an ECM8000 microphone and tend to forget how to use the RS meter.
Anyway, there's no reason for you not to manually turn up the input volume in REW if the automatic setting doesn't work for you.
Old 12-04-06, 06:16 PM   #16
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
while i re-calibrate with the 80 RS meter dial setting, can you tell me how to set
"Use horizontal axis of 15Hz to 200Hz and vertical axis of 45dB to 105dB." ?
I tried zooming in, but that only half-*** works
Old 12-04-06, 06:28 PM   #17
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
now i'm totally confused.
On the back of my audigy, I think i had my receiver connected to the wrong jack?
I think i had it connected to the Speaker jack, when it should have been connected to the Line Out jack? I'm totally NOT sure which jack that is, and on top of that, the only option under SB Audigy (which is just above the set measurement level button in REQE) is SPEAKER ... no Line Out or anything else listed there at all.
Are Speaker and Line Out the same thing?
EDIT for picture...
http://www.imagemonster.net/is.php?i...9759audigy.jpg
Old 12-04-06, 06:38 PM   #18
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
I really should PS the above post.
When i connect the receivers 1/8 jack to the 'Line Out' in that photo i get nothing. When i connect it to the 'speaker' in that photo, i get sound.
By my logic, the latter is correct. Yes / no?
the REQW always uses the term Line Out, and specifically says that "output volume should not effect line out but may effect headphone or speaker outputs"
Unless i'm mistaken, the SB Audigy does not have a Line Out jack.
Old 12-04-06, 06:59 PM   #19
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
Is there any way to set everything to the default settings in REQW?
This thing seems to be getting totally FUBAR'd with all the messing around i've done today.
Old 12-04-06, 07:04 PM   #20
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
Can i just ask one basic question?
I'd love to know exactly why when i click 'SET MEASUREMENT LEVEL' and do what i'm told to, and then click 'SET INPUT LEVEL' the set input level fails?
If I increase any of the other volume controls, i'm falsley inflating the output compared to the just calibrated setting, making the whole calibration incorrect.
Old 12-04-06, 07:08 PM   #21
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
another real basic quandry: i've got the mic plugged in and it's sitting at my listening position. With no noise in the room it's outputting a measurement of 68db or more.
Is it just me, or is that all out of whack? when the kids run upstairs, it spikes to over 80db ... just seems it's too sensitive or something.
Maybe i'm just totally frustrated because i'm getting confused and not getting anywhere, i don't know
Thank you for all the time you've put into this thread regardless.
Old 12-04-06, 07:20 PM   #22
Alias: brucek
User: #6
  brucek is offline
Click the icon "set graph axis extends" located at the bottom right hand side of the graph and set the axis. It will remember the values the next time you click it.
Just look in your manual or download the manual if you don't have one. There will be a line-out. I don't know if they call it speaker. I don't know your model of Audigy - there are many types.
REW uses the term speaker out, select that one.
You should. Ensure Line-out isn't muted in your control panel mixer.
All the level settings are on the screen for you to set as you wish. There is no real default.
Old 12-04-06, 07:32 PM   #23
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
OK, i've got the correct graph axis etc. set at least...
In regards to this... there is no Line-Out in my control panel mixer.
Could it perhaps be 'Auxilary' ?
Old 12-04-06, 07:43 PM   #24
CSEmoses
Inactive
Alias:
User: #
Posts: n/a
I've verified via online download of Audigy manual that i've got the correct connections. The one I use for my headphones IS the Line-Out, it supports headphones.
At least, next time I start this again, I know i've got the correct connections made.
Old 12-04-06, 08:14 PM   #25
Alias: brucek
User: #6
  brucek is offline
OK, great.
Yeah Ok, I should have said be sure that WAVE was not muted.
I just looked at mine and here's a pic of the Recording Mixer and Playback Mixer and what controls the levels in REW and what should ne unmuted.
Name:  mixer RealTek.jpg
