| REW Forum REW and BFD ResultsDiscuss REW and BFD Results in the Subwoofer Equalization | Calibration forum; REW and BFD Results First I must say Well Done on the BFD and REW Guides. I was able to set everything up and ... |
| | #1 (Link) | |||
| REW and BFD Results First I must say Well Done on the BFD and REW Guides. I was able to set everything up and get measurements first time around!My room is a family room with openings to the kitchen and hallways and an 8 ft ceiling. The sub is located next to the coach under the house plant. Placement recommended by Dr Hsu. Drawing not to scale. Family Room.jpg My system: Yamaha RX-V2500 Paradigm Monitor 11 v.4 Mains Paradigm CC-370 v.4 Center The Surrounds and Surround Back are umm... Bose Accoustimass 15 HSU VTF-3 Mk2 in Maximum Extension mode Sony XBR 34" Direct View HDTV Sony DVD player I first mesured the sub response with an Analog Radio Shack SPL Meter using sine waves from this site and plotting manually on the New RS Analog Excel spreadsheet. This led me to REW. I downloaded REW and purchased both a BFD and a Sound Blaster Live 24 bit sound card on eBay. With a few adapters from Radio Shack I was ready to begin. First I used YPAO to set up the levels, etc. Then I measured, set filters on the BFD and measured again, adjusted output on the sub, measured again... I was able to achieve a pretty decent response with a gentle +8 dB house curve from 60 Hz to 20 Hz. This was achieved with 7 cuts and one 5 dB boost at 35 Hz. The best integration with the mains was achieved with a crossover of 90 Hz on the AVR and setting the crossover on the sub to IN also at 90 Hz. I've often read it is bad to have cascading crossovers but in my case it seems to work! The 90 Hz crossover also benefits the CC-370 (-2 dB @ 100 Hz) but is a little high for the Monitor 11s (-2 dB @ 48 Hz) The measurements were taken at the center position of the couch. The results are even smoother on the right position. The left position has a very large null at 35 Hz. I will post graphs later today. Now I can hear sounds I never heard before. The overall effect is smoother more defined bass without the 25 Hz and 50 Hz Mode excitement caused by the room. | |||
| | #2 (Link) | ||||||
| Re: REW and BFD Results Quote:
Hope you can post a before and after graph..... ![]() brucek | ||||||
| | #3 (Link) | |||
| Re: REW and BFD Results Here is the sub only, 90 Hz cutoff with BFD hsu vtf-3 mk2 graph1.jpg Filters applied 12_1_06.req Here is the sub plus mains, 90 Hz cutoff with BFD hsu vtf-3 mk2 graph2.jpg | |||
| | #4 (Link) | |||
| Re: REW and BFD Results Here is the sub only no BFD crossover 90 Hz sub crossover out hsu vtf-3 mk2 graph3.jpg Here is the sub and mains no BFD crossover 90 Hz sub crossover out hsu vtf-3 mk2 graph4.jpg | |||
| | #5 (Link) | |||
| Re: REW and BFD Results Let's try the waterfall again Sub Only with BFD hsu vtf-3 mk2 waterfall1.jpg Sub plus mains with BFD hsu vtf-3 mk2 waterfall2.jpg | |||
| | #6 (Link) | ||||
The sub is currently near the only usable rear corner. Chuck | ||||
| | #7 (Link) | |||
| Re: REW and BFD Results Waterfall sub only no BFD hsu vtf-3 mk2 waterfall3.jpg Waterfall sub with mains no BFD hsu vtf-3 mk2 waterfall4.jpg | |||
| | #8 (Link) | ||||
I wonder if anyone else here has experience or knowledge of that. Great looking response - good job.... brucek | ||||
| | #9 (Link) | |||
| Re: REW and BFD Results A couple of years ago I asked Dr. Hsu where to place my sub too. I think his recommendation is usually to put it in a corner farthest from unclosable openings in order to realize maximum corner gain. Since then I've come to the conclusion that maximizing gain from corner placement shouldn't be your first concern, unless you are pushing the limits of the sub. Smoother frequency response, better directionality and more consistency from seat to seat can be obtained by moving the sub to the front and away from the corners. Could you try it next to the TV? We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
| | #10 (Link) | ||||
There is a steep 10 dB drop from about 23 Hz to 21 Hz. Then it levels out. I kept the peak at 80 Hz since it levels out with the mains. I haven't done any critical listening yet. hsu vtf-3 mk2 graph5.jpg hsu vtf-3 mk2 graph6.jpg Chuck | ||||
| | #11 (Link) | |||
| Re: REW and BFD Results I fine tuned the filters. Even though I lost some low end extension, the response is consistent across the viewing area. Any recommendations? hsu vtf-3 mk2 graph7.jpg hsu vtf-3 mk2 waterfall5.jpg hsu vtf-3 mk2 graph8.jpg hsu vtf-3 mk2 waterfall6.jpg | |||
| | #12 (Link) | |||
| | Re: REW and BFD Results That’s a really tough room you have there. If you got response that good, and it’s reasonably consistent through most of the room, I’d say you’re done – stick a fork in it! Looks like you got good response down to about 24 Hz before response starts dropping – most people agree that’s low enough to deliver a satisfying home theater experience. Regards, Wayne | |||
| | #13 (Link) | ||||
In fact, if it were me, I would do some more cutting and then raise the sub amp a bit and end up with a response that went down to ~18Hz. 18graph.jpg brucek | ||||
| | #14 (Link) | ||||
Chuck | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Suggestions for BFD and REW Tips | Sonnie | REW Forum | 10 | 05-03-08 12:54 PM |
| First Round w/ REW -- Mixed Results | Woochifer | REW Forum | 1 | 11-17-06 08:44 PM |
| My BFD / REW results | brucek | REW Forum | 6 | 11-11-06 09:53 AM |
| What do I need to Interface BFD with REW? | sportsound | REW Forum | 3 | 05-06-06 12:55 PM |
| BFD recommendations and Results | jeffbridges | BFD Forum | 1 | 04-25-06 09:18 PM |
