| REW Forum REW Mac OS X problemsDiscuss REW Mac OS X problems in the Equalization | Calibration forum; REW Mac OS X problems I'm trying to run REW on a Macbook and I'm having problems. The initial setup goes fine until I get ... |
Views: 1227 - Replies: 15
| REW Mac OS X problems I'm trying to run REW on a Macbook and I'm having problems. The initial setup goes fine until I get to the step where you Measure Soundcard Response - I get an error dialog that says the measurement may be corrupted. I'm using the line input on the Macbook, and it appears that I can't get the input gain low enough. I purchased a Griffin iMic which is basically a USB soundcard and have different problems. Output of the iMic works, but input doesn't. When I select the iMic as input on the system preferences, REW either throws an exception or uses the Macbook internal microphone. I'm also experiencing the popping sound when generating pink noise reported in another thread. Rather than turn to the dark side and use that other operating system, I'd be interested in helping find root cause of these problems. John, would you be interested in working with me? I have plenty of experience coding java and debugging tough problems - just not a lot of experience with audio algorithms. Bryan | ||||
| | #2 | ||||
| Re: REW Mac OS X problems There is a dedicated MAC OS 10 acoustics product out there called FuzzMeasure pro http://www.supermegaultragroovy.com/...asure/index.py not free, but cheaper than turning to the dark side.... | ||||
| | #3 | ||||
| Re: REW Mac OS X problems I ordered an M-Audio MobilePre with hopes that it'll work well, and avoid the problems with using the built-in mic-in speaker-out on my IBM T43 laptop. I plan to try using the MobilePre with my iBook instead, and see how it works. | ||||
| | #4 | ||||
| Re: REW Mac OS X problems Hi Bryan, Yes, I'd like to get the app working properly on the Mac, though I expect I'll have to use Apple's CoreAudio classes to do it as they don't bother to support most of the standard JavaSound methods (gits). I've bought a Mac Mini to use as a dev platform, which has also thrown up a lot of UI and rendering issues which don't occur on the PC or Linux platforms so quite a few things to sort out. I'll get stuck into it after I release the next version of REW, which should be just before Xmas. | ||||
| | #6 | ||||
| Re: REW Mac OS X problems bhunt: were you using digital or analog output? I have clicking on digital output, but so far so good on analog. It is too late to give it a shot tonight, but tomorrow I will be trying to do a few runs, but the loopback on a mbp c2d works great now. | ||||
| | #7 | ||||
| Re: REW Mac OS X problems I am having the clicking too, so I didn't tune through my receiver since I was afraid of damaging the speakers. I was using the optical output. I'll try the analog too! | ||||
| | #8 | ||||
| Re: REW Mac OS X problems I've got rid of the Mac clicks on the latest dev build through a combination of audio handling changes and a new output mixer from Mandolane. The Mandolane mixer can't be used with the current REW release build, unfortunately, but I'll get a new build out before the end of the year. | ||||
| | #9 | ||||
| Re: REW Mac OS X problems Hi John, Just curious if you still plan to release the new build that eliminates the popping? If there's anything I do to to help, test, etc, please let me know. | ||||
| | #10 | ||||
| Re: REW Mac OS X problems Hi Daryn, That build is in beta testing right now, I'll get the jar files together and PM you a link to try it. I have been using it with Mandolane's new mixer, but it may also work better with the Apple mixer. On the input side, Leopard seems to have sorted the problem with not being able to access inputs other than the built-in audio. | ||||
| | #12 | ||||
| Re: REW Mac OS X problems Download the new V4.10 OS X application bundle ![]() | ||||
| | #14 | ||||
| Re: REW Mac OS X problems There are 2 other things you can try: - Adjust the replay buffer size on the soundcard settings tab, it defaults to 32k but try 16k and 64k to see if either helps - Try the low latency output mixer from Mandolane, http://www.mandolane.co.uk/swM3DMixer.html currently it is a free beta version but only to the end of April. However if you are using the Mandolane midi library the mixer will be free. | ||||
| | #15 | |||||
| Re: REW Mac OS X problems Quote:
| | #16 | ||||
| Re: REW Mac OS X problems Nothing else I can think of. Worth trying the Mandolane mixer, it is easily uninstalled if it doesn't help. | ||||
